Old 27th May 2009, 02:53 PM   #1
xcicc is offline xcicc  Italy
xcicc's Avatar
Default new ampli with IRF240
Hi, I just finished assembling this amplifier based on this project.
http://www.redcircuits.com/Page100.htm
I plugged it all but feel the music just croak the mosfet fortunately no heat and no feel smell of burning.
On series of 220v I connecteda 220v 60W light bulb to limit the current, turning the trimmer does not change anything ...
any ideas?
thanks
Old 27th May 2009, 04:32 PM   #2
sakis is online now sakis  Greece
sakis's Avatar
Default can you draw a schematic ??
to see how this is working ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 27th May 2009, 04:32 PM   #3
ostripper's Avatar
The most obvious thing is r14/15, those should be .33 ohm ,not 33R. Nice hand made layout , thought I was only one who did that (besides carlos - DX).
OS
edit: another issue, even if you get it to amplify with the resistors,the circuit calls for lateral mosfets(it lies!!). All is not lost , you could make a small daughtercard with cap, 2 resistors, trimmer and Bd139/mje340 to give thermal stability.
Old 27th May 2009, 05:42 PM   #4
xcicc's Avatar
OS
I agree tomorrow will replace these resistors, although I think that is not the only error.
thanks
A.
Old 27th May 2009, 05:52 PM   #5
AndrewT is online now AndrewT  Scotland
the parts list is wrong.
Do not reduce the source resistors just yet.
You may damage the output devices if you can get sufficient current to turn them on.
The circuit shown in the schematic is designed to ONLY suit Lateral MOSFETs.
It MUST be REDESIGNED to suit Vertical MOSFETs.
Have alook at Vgs for the irf240 and irf9240 that you have fitted.
Now measure the bias voltage you are applying across the gates.
It will not work as is, because the wrong devices have been listed in the parts list.
regards Andrew T.
Old 27th May 2009, 05:56 PM   #6
xcicc's Avatar
want to say that this amp will not work ever?
I did not understand what I should do, change what?
I also have a doubt about diode 1n4007 and LED
I fear that I have mounted on the contrary.
thanks
Old 27th May 2009, 07:20 PM   #7
ostripper's Avatar
Andrew is right , for the IRF's a major redesign would be in order , a proper active Vbias circuit + driver stage would be needed. take a look at the quasi line of DIY amps , they use just IRFP240's , but they are proven designs.
Power amp under development
For what you have made, besides the resistors , just jumper the led and diode , leave the trimmer , use 2SK1058/2SJ162 lateral's.
Attached is a similar Op stage to yours the way it should be. (really works).
OS
Old 27th May 2009, 07:25 PM   #8
xcicc's Avatar
OS
I do not understand what the project is completely wrong? will not work ever? in other words this ampli whith mosfet IRFP240/9240 can not be built?
with your modification you've redesigned everything.
I do not understand why I have to add another 2 mosfet
or your changes are only to improve?
thanks
Old 27th May 2009, 07:56 PM   #9
I've already done this with small IRF640 and 9640, it becomes quite warm at full output, and sounds excellent! I uses it as guitar amp, this must be one of the best designs, pretty simple, no distortion... cool!
Old 27th May 2009, 08:06 PM   #10
ostripper's Avatar
That was just to show you the "way" , you don't have to use 2 pairs of devices!!
IRF's increase current with heat , so they need something to negate this effect. With a HUGE heatsink , you might get away with it.
Slideman uses the to-220 irf's , they would work with a huge HS, but the big 240's would soon go into runaway.
OS
aleph1.2 IRF240 vs IRFP250 klimo_67 Pass Labs 20 8th April 2010 02:17 PM
Advangages of using new IRF240 in TO-204 package? hifimaker Pass Labs 23 6th January 2006 01:23 AM
mosfet 450w irf240 / irfp9240 amp help aletheian Solid State 5 29th August 2005 03:20 AM
IRF240 for sale please see link dhole Pass Labs 1 18th July 2005 05:01 PM
Can i substitute IRF540 with IRF240 ?? hifi Solid State 5 20th March 2001 06:50 PM
Page generated in 0.11014 seconds (82.63% PHP - 17.37% MySQL) with 11 queries
