3T HeadPh Amp. JFET-BJT-MOSFET
Old 30th May 2009, 02:32 AM   #31
lineup is offline lineup  Sweden
lineup's Avatar
Lumba Ogir
Just dont tell me what to do.
tank u
Just because you are not lucky to have a good sim
does not mean we all, that like to use them, should do like you
If you prefer your imagination, which is much more virtual than a good simulator of reality,
then this is your own decision
horrible if we edcuated out pilots for passenger airplanes
in imagnary & hypotetic models, just out of human subjective thinking.
I would not want to ride in such a plane.
I prefer those that has excercised emergency situations baed on matemaical virtual softwares.
Modelas of reality.
I get you do not even use roadmaps .. but does this make easier for you to find your way.
And you do not look at local weather forecast, cretaed by simulations of real data from stations
A roadmap is a virtual representation of reality.
And it works well. Do you have a car?
Same with the precision tools we use to represent electronical circuits.
They are based on real data, often a good average of the qualities of real components.
Imagniation & unprofeed hypotesis can be fun for you
but let's separate facts & figures from subjective an not validated thinking about real circuits.
They are often much less valid than the models I use here.
I end here with my weather forecast in first post.
It tuns out it came true. Not dificult to know this in advance.
It was based on empirical observations od www.diyaudio.com reality
Be back with schematics, AC-analyses and Fourier for discussion/evaluation.
All is properly tested in virtual circuit with some of the best instruments we can find.
On the commercial ground my simulator costs way too much.
From this we can forsee, that this topic will not discuss my circuit.
But people will do more postings of the usual debate on using sims, paper or calculator
or design by listening to transistors output through headphones of different qualities
after throwing it quickly together with solder.
thanks
linie - lineup
lineup
Old 30th May 2009, 02:53 AM   #32
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
lineup,
Wasted money.
Old 30th May 2009, 03:35 AM   #33
lineup's Avatar
If you want to discuss my circuit
and the testings of it .. then welcome, Lumba.
I wont feed the trolls here.
I let others do that
much regards to you for being intesrested
and read and learn some real things
yours linie
lineup
Old 30th May 2009, 12:05 PM   #34
lineup's Avatar
AC Analysis of Version 7b (with diode optimized output).
The GBW (voltage gain x upper bandwidth limit)
of this version is = 29 MHz
Closed loop Gain = 6.50
Closed loop max stable Bandwidth = 4.50 MHz
I decided to use 33p Miller to get the upper freq to rolloff at 1.2 MHz.
By doing this I do not need so heavey a filter at input of JFET
and so risc some corruptions of frequency curve, because of how I adjust My volume pot.
After all I am not designing ShortWave radio circuit here,
but a real Hifi Headphones amplifier
conerning with good reproduction of audioband: Max 20.000 Hertz (=0.020 MHz).
Not much to comment else. But if you have any questions I may consider answer you.
Trolls like Lumba can be at times
and other destroyers of my good threads .. dont bother, please
I will try to ignore stupid comments as much as my mind allows me.
/lineup the cool guy .. at least this morning
File Type: png lineup_hpa_version_7b_optimal-ac_public.png (5.7 KB, 246 views)
lineup
Old 30th May 2009, 12:32 PM   #35
artquake is offline artquake
Thank you lineup, for your informations ... i'll check the links you mentioned.
the truth is somewere
Old 30th May 2009, 12:42 PM   #36
Banned
lineup,
A woeful decision.
Old 31st May 2009, 06:12 PM   #37
Hi Lineup,
I just soldered the following amp for my cans ... since i had all parts available here it was a short run ... very impressive how powerfull it is ... Driving 40 Ohms (Sony), 62 Ohms (AKG), as well as Senns @ 600 Ohms ... i very content with it ... son now the finish of the enclosure and all will need about a ten or twenty times more time then the soldering ... pah ...
Have a peak :
Schematic
Source
I found the link from a post from you here in the forum ...
So thanx for the hint.
EDIT:
BTW i forgot to say ... this amp can make'em sound really loud !
regards
artQuake
Old 5th June 2009, 07:05 AM   #38
lineup's Avatar
Default 12 Volt operation
For 12 volt operation
we can start thinking 2SK170BL or 2SK170GR
.. in fact in my 12 volt version I used 2SK170BL
running at like 0.5mA for input.
For 24 V .. the 2SK170 might give a little too high voltage gain
.. especially for 16/32 Ohms phones.
For 12 Volt and 32 Ohms .. 2SK170 input like in my design here
will work very well.
/line 'linie' lineup one designer
lineup
Old 7th June 2009, 11:36 PM   #39
lineup's Avatar
Cool 2SK170BL JFET Headphone for 12 Volt DC
My recommended circuit for 12 VDC.
Phreaking low distortion !!!!
if you can find one optimal resistor: R4=96.5 Ohm
Because this base stopper removes a lot of 2nd harmonics dist
in output stage.
Changes:
1. JFET 2SK170BL (IDSS=8mA) set at 0.5mA operation
2. ZVP3306 ZETEX great TO-92 P-MOS, set at 10 mA operation
3. BD140-16 as output for 120 mA bjt Class A operation,
into 33 Ohm power resistor
Enjoy !!!
lineup
Old 4th July 2009, 07:28 PM   #40
Bigun is offline Bigun  Canada
Bigun's Avatar
Now this looks very interesting ! -- I like the FET driving the BJT.
I wish I had some headphones now
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
3T HeadPh Amp. JFET-BJT-MOSFETHide this!Advertise here!
Jfet/Mosfet cascode with OPT Fuling Pass Labs 10 3rd December 2007 05:53 PM
MOSFET or JFET Faust3D Solid State 17 29th November 2007 04:46 PM
10W JFET/MOSFET SE Class A, no Feed Back widowmaker Solid State 9 26th November 2006 01:00 PM
Need good current sink JFET or MOSFET? rlaury Tubes / Valves 7 22nd November 2005 06:14 AM
Copyright ©1999-2017 diyAudio
