Old 23rd May 2009, 12:23 PM   #1
destroyer X's Avatar
Default Do you know the reason why so big voltage to the input circuit?
sometimes if feel those guys had exagerated a little..seems a Sony designer.
ahahahahah!
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 23rd May 2009, 12:35 PM   #2
Default This circuit seems to be one of the Sony Professional
amplifiers..some modification or another idea about... those TAN series of pulse width modulation supply and legato linear circuitry.
This is more modern than the Legato.... seems Sony...or Sony style.
I am studying some schematics and found this one as i had listened the Sony TAN88, down the eigthies (1981) into the Studio i have worked.
I found it mufled compared to others those early days... even together Sony SG7 speaker that was made matched to that amplifier.
regards,
Carlos
Old 23rd May 2009, 04:36 PM   #3
Default No one knows?
yep...it is really too much volts there.
Me too... i do not know...reason why asking you.
regards,
Carlos
Old 23rd May 2009, 05:32 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Carlos, this schematic is not from the TA-N88, I guess you know that.
The high voltage is a trick that was often used at the time by Japanese manufacturers to get the input stages to operate linearly. The signal excursions are now a much smaller proportion of the total available voltage swing. If you look at the load line, there is only a relatively small excursion and over that smaller excursion, the line is more linear.
They sometimes also did it in preamps. I have a Sony preamp that has the phono preamp running at +/-50V...
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 23rd May 2009, 05:38 PM   #5
Mooly's Avatar
I used to have a Pioneer A80 circa 1985 ish. That ran the phono stage on something like -/+ 60volts. Even madder it was class G, the "low" voltage rails to the output were again around -/+ 60 ish switching to -/+ 75 or so.
But I've learnt a lot since then
Old 23rd May 2009, 06:19 PM   #6
Default Yep..but this one has high voltage to the input circuit....not to the power stages
crazy thing that.
regards Mooly.... i will not eat cow meat today... relax!
Carlos
Old 23rd May 2009, 06:20 PM   #7
Default Thank you Jan Didden.
So it is not a Sony.
I am glad to know that.
thank you,
regards,
Carlos
Music from the eigthies boys!
http://www.tropicalglen.com/Jukebox/.../myjukebox.swf
voltage balancer circuit zilog Power Supplies 0 17th April 2008 08:52 PM
Input voltage lpd Tubes / Valves 2 11th July 2006 05:49 PM
New SPDIF input circuit. gmarsh Digital Source 11 7th April 2005 03:05 PM
Input voltage seahag Chip Amps 4 30th November 2004 03:34 PM
Low voltage cutoff circuit? zmoz Parts 3 20th June 2003 09:46 AM
Page generated in 0.10173 seconds (79.12% PHP - 20.88% MySQL) with 11 queries
