Paralleling or Cascading Power Supply Filter capacitors question
Old 29th April 2003, 02:44 AM   #1
KevinLee is offline KevinLee  Canada
Default Paralleling or Cascading Power Supply Filter capacitors question
Hello Everyone,
My integrated amplifier came stock with (2) 6,800uf filter caps in the power supply. I have added (2) 22,000uf Cerafine caps to the 6,8000uf for a total of 28,800uf per rail.
I like the added base tightness and depth that I now hear.
I am looking at upgrading the original 6,800uf caps to better such as 'Elna for Audio' or Nichicon Gold.
I have heard that when cascading caps that the smaller cap should be no more than 10% the size of the larger cap.
If this holds true, will I receive even better performance from my amp if I pitch the 6,800uf caps and replace them with 2,200uf?
If no gain is to be had by pitching the 6,800uf size for 2,200uf , might some benefit be had by replacing the 6,800uf with smaller versions totalling 6,800uf?
Any advice or experiences would be greatly appreciated.
I am hoping to speed up the pace of the amp a little.
KevinLee
Old 29th April 2003, 03:08 AM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Paralleling or Cascading Power Supply Filter capacitors question Send a message via AIM to Peter Daniel
If you added 22,000u Cerafines you might think about removing 6,800 caps alltogether if they are not close in quality to Cerafines. I don't think the improvement be obtained with different values, but rather the quality of caps. Try disconnecting old caps and observe the difference, then act accordingly. Further improvement might be done by adding quality film caps (even 1U can make a difference) or BG type N caps. I remeber you bought some Os Cons, try them
To order kits contact me through forum mail.
Old 29th April 2003, 04:04 AM   #3
trigon is offline trigon
trigon's Avatar
Don't forget to replace PS bridge with these diodes 40cpq100 that you allready have
Trigon.
Old 29th April 2003, 05:57 AM   #4
Trigon.
Something tells me that you have them too
Old 29th April 2003, 12:13 PM   #5
Thanks for the info Peter.
I will try removing the 6,800uf caps all together.
If I like the sound I may add good quality 2uf film cap.
I have replaced my bridge with (4) 30 amp Fairchild 'stealth' diodes and I do like the sound of the new bridge.
I will let you know how it sounds when I make the changes.
KevinLee
Paralleling or Cascading Power Supply Filter capacitors questionHide this!Advertise here!
paralleling computer power supply outputs: can they be connected in parallel... jarthel Parts 7 12th December 2012 09:13 PM
Paralleling low trr diodes in a PS with capacitors legarem Solid State 2 28th November 2008 10:30 AM
paralleling capacitors and avoiding resonance zilog Power Supplies 8 25th October 2006 12:02 PM
Power supply decoupling capacitors (beginner question) bm_mode Solid State 5 26th March 2002 01:29 AM
