Old 22nd May 2009, 09:44 AM   #1
Default 2sa1494 replacements ?
hi all ,
first time to post here.have some problem with amp and hope you guys can give me some advice .
i have a blew 2sa1494 and 2sc3858.i can't get the same at my town .the shopper tell me that 2sa1216 and 2sc2922 will be the same . after solder all the part,it looks and works fine.but it gets fairy hot very fast . i have no idea what's wrong and hope someone can help me it this .Thanks!!!
Old 22nd May 2009, 10:02 AM   #2
AndrewT is online now AndrewT  Scotland
you probably have not checked and adjusted the output bias current.
If Vbe of the new devices is just slightly lower than the original devices then the output passes a lot more current and this results in much higher power dissipation and heatsink temperatures.
You need to find the set up instructions for the output stage and adjust to the correct values.
Don't use this modified/repaired amplifier until this is attended to properly.
regards Andrew T.
Old 23rd May 2009, 02:09 PM   #3
Dear Andrew ,
thanks for the reply. can you explain more detail .because i am really new to diy.Thanks again!!!
Old 23rd May 2009, 04:19 PM   #4
find or ask for the setup instructions.
regards Andrew T.
2sa1494/2sc3858 2sa1216/2sc2922 uhcmos Swap Meet 0 30th October 2008 01:01 PM
2sd1213 replacements shagone Car Audio 2 28th May 2008 12:45 AM
replacements doktor Solid State 8 10th March 2008 12:11 PM
Transistor replacements glen65 Solid State 1 19th November 2007 07:48 PM
BC327/337 replacements udip Parts 14 24th January 2005 04:57 AM
Page generated in 0.05942 seconds (80.52% PHP - 19.48% MySQL) with 10 queries
