Old 20th May 2009, 06:00 PM   #1
Default Moding this phono preamp ?
Hello
A friend bring me a RCA phono preamp, I will recap it and mod it for him.
Any suggestion of better transistors than the 2SC2240 for higher gain and lower noise ?
The schematic was in the cover of this preamp, it's a quite simple one, but can it be modified a bit to be better ?
Thank
Bye
Gaetan
Old 20th May 2009, 06:32 PM   #2
Hello
How about the MPSA18 to replace the 2SC2240 ?
Thank
Bye
Gaetan
Old 20th May 2009, 07:07 PM   #3
syn08 is offline syn08  Canada
Originally posted by gaetan8888
Hello
Thank
Bye
Gaetan
MPSA18 will only worsen the noise. 2SC2240 is a very good low noise device, Made In Toshiba.
The original design has negative feedback, so changing the trasistors will barely impact the gain. Besides, you don't want to change the gain, anyway.
Leave it as is on the transistors side.
Old 20th May 2009, 09:43 PM   #4
Hello
I have lot of MPSA18, and I have also lot of BC546 and 2N5551 but they are a bit noisyer than the 2SC2240.
Looking at the schematic, the gain are maby too low for a stand-alone phono preamp, so it could be a kind of phono adaptor who would be plug into the input of a line preamp, since lot of preamp or integrated amps today do not have a phono input.
At least it have a voltage regulator.
Thank
Bye
Gaetan
Old 20th May 2009, 10:31 PM   #5
mjf is offline mjf  Austria
hello.
the power supply cap (c 107 220uf/50v) is really small...........i would use a bigger one (1000uf or so.....).
the volt rating of the filter cap c99(100uf/25v) is to low.......i would use a cap with 35v or so........
output cap c 56(0,22uf) is small..........2,2uf or more.
input cap c 54 (4,7uf) could be substituted with a film cap 1uf (quality of filmcaps is better than elco's).
greetings................
Old 21st May 2009, 01:41 AM   #6
Hello
I agree about those cap, that's why I was intend to recap the preamp and ps.
So, even with only two transistors, (after changing those caps)that preamp circuit are good ?
Thank
Bye
Gaetan
Old 21st May 2009, 01:52 AM   #7
Hello
After a close look at the preamp board, I've found one 1K resistor who was not on the schematic, so here is a revised schematic with that 1K resistor between the power supply and the right and left channel of the preamp.
Thank
Bye
Gaetan
Old 21st May 2009, 07:43 AM   #8
hello.
that is a simple standard circuit.it was very often used in amplifiers and receivers (my old beomaster 1000 uses it too...).minimalistic but it works........
Old 21st May 2009, 08:06 AM   #9
there is annother example for that kind of phonopreamp.......they all are similar...........
Old 21st May 2009, 09:06 AM   #10
homemodder's Avatar
Gaetan
Have a look at the adressing John curl concerns on low noise design, theres some good input there concerning transistor selection in the last 2, 3 pages.
phono preamp? losacco Tubes / Valves 2 13th January 2009 08:15 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Moding Car Amp Superblunt Car Audio 1 23rd April 2005 06:38 PM
Phono PreAmp JTT Analogue Source 20 15th September 2004 04:24 PM
Page generated in 0.10070 seconds (77.18% PHP - 22.82% MySQL) with 11 queries
