Hi~
Anyone have TIP142 and TIP147 LTspice model? I only can find Pspice model for TIP147 darlington transistor Is it able to convert it into LTspice model? ************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * * Modeling services provided by * * Interface Technologies www.i-t.com * ************************************** .SUBCKT tip147 1 2 3 * Model generated on Feb 8, 2004 * Model format: PSpice * Darlington macro model * External node designations * Node 1 -> Collect * Node 2 -> Base * Node 3 -> Emitter Q1 1 2 4 qmodel Q2 1 4 3 q1model 9.26065 D1 1 3 dmodel R1 2 4 8000 R2 4 3 40 * Default values used in dmodel * EG=1.11 TT=0 BV=infinite .MODEL dmodel d +IS=1e-12 RS=10 N=1 XTI=3 +CJO=0 VJ=0.75 M=0.33 FC=0.5 .MODEL qmodel pnp +IS=1.03024e-14 BF=257.093 NF=1.2 VAF=679.126 +IKF=0.190032 ISE=1.23159e-13 NE=1.73997 BR=1.10206 +NR=1.19838 VAR=126.182 IKR=0.103332 ISC=1.23159e-13 +NC=2 RB=5.06065 IRB=0.2 RBM=5.06065 +RE=0.199903 RC=2.01466 XTB=0.354371 XTI=3.01199 EG=1.206 +CJE=1e-11 VJE=0.75 MJE=0.33 TF=1e-09 +XTF=1 VTF=10 ITF=0.01 CJC=1.67157e-09 +VJC=0.95 MJC=0.23 XCJC=0.9 FC=0.5 +TR=1e-07 PTF=0 KF=0 AF=1 .MODEL q1model pnp +IS=1.03024e-14 BF=257.093 NF=1.2 VAF=679.126 +IKF=0.190032 ISE=1.23159e-13 NE=1.73997 BR=1.10206 +NR=1.19838 VAR=126.182 IKR=0.103332 ISC=1.23159e-13 +NC=2 RB=5.06065 IRB=0.2 RBM=5.06065 +RE=0.199903 RC=2.01466 XTB=0.354371 XTI=3.01199 EG=1.206 +CJE=1e-11 VJE=0.75 MJE=0.33 TF=1e-09 +XTF=1 VTF=10 ITF=0.01 CJC=0 +VJC=0.95 MJC=0.23 XCJC=0.9 FC=0.5 +TR=1e-07 PTF=0 KF=0 AF=1 .ENDS |
#2 |
This model should work with LTspice.
#3 |
Since this is a .subckt, this is what you need to do to use the model. Click the right mouse button on the component (in this case the PNP) while pressing the CTRL key down, and in the dialogue that will open, replace QP with X, and for VALUE write TIP137 or whatever the .subckt is.
The text that you showed can be saved in a file named tip137.lib, and then with a spice statement (.op button) it can get included: .lib tip137.lib as long as the file is placed in the c:\...\LTC\LTspiceIV\lib\sub\ or wherever your ltspice was installed. Hope this helps. |
#4 | |
thank for the help I had try out your method It's just show an error. (screen shot attached) What do you mean by ".op button" ? |
#5 |
There is a button on the toolbar, on the upper right-hand side, named ".op" or something like that. When you click on it allows you to insert a spice directive. The directive that you type in should be
.lib tip142.lib for that component. Then you place that next to your circuit, after you press OK, since your mouse cursor will have that writing attached to it. |
#6 |
Yes~
It is working now! thanks a lot =) |
#7 |
I wonder if I can get your advice here ikoflexer .
I have been trying to load a model for the IRF9610. I have it saved to the desktop in a text file and try to "save as" to the lib/sub folder as an all files file type with the name IRF9610.lib . When I run LTSpice I get the response "Could not open the library file IRF9610.lib" which is better than I was getting til I read your posts here. Can you give me a little more detail about how to create the file for the folder? (As all files I did try all four types of encoding listed but to no avail.) Thanks |
| 10m45s LTspice model | dave slagle | Tubes / Valves | 10 | 19th October 2011 04:37 PM |
| Does anyone know of an LTSpice model for 12B4? | ray_moth | Tubes / Valves | 2 | 28th May 2008 09:12 AM |
| LTSPICE IRF820 model | rafafredd | Pass Labs | 2 | 11th August 2007 05:01 PM |
| LTSpice - some help with model needed | Cybergent | Everything Else | 4 | 29th October 2005 11:14 PM |
| Page generated in 0.11949 seconds (79.25% PHP - 20.75% MySQL) with 11 queries |
