Hey guys, i apologize if this isnt audio exactly, but it has to do with transistors which i know is involved with audio amplification.
I am wondering if this is correct: i am wanting to fully saturate the transistor (2N4401, Ic max = 600mA, Hfe min = 40). the base will be at a variable voltage; as temp increases, so does the voltage; this voltage is off of a set of fans. The reason being that i want to make this is because no matter what the voltage is between 7-12volts, i want the output to the computer fan be 12 volts. Thank you for your time! |
#2 |
this means power and heat.... heatsink gonna be needed too. Use a diode from base to emitter...to protect your base to emitter junction against over voltage.... you do not need to enter with all that voltage....less than 1 volt, with a very small current, will turn the transistor on. So, use that current limiting resistance you have installed into the base, but install a diode with arrow pointing down.... not a very small diode...use a 1 ampere one for safety reasons.... more reliable. this way voltage gonna be controled by the diode... it will keep voltage into the base sligtly bigger than 600 milivolts, but will not allow base to have bigger than that Transistor, into saturation mode (switch "on") will have a voltage from coletor to emitter (saturation voltage).... this voltage will reduce, sligtly, your voltage to the fans.... voltage will be reduce by almost 0.5 volt regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#3 |
Thank you for the reply.
I have a few questions: 1.) About the size of the transistor: The fan I will be operating will pull 260mA @ 12 volts. The noise isnt a factor because this will be inside of an Xbox 360. The DVD drive will be WAY more noisy than the fan will ever be so noise isnt really a factor. I am putting a fan directly over the CPU and extended graphics processor heat sink; that thing gets burning hot when played for an extended period of time. 2.) About the voltage: From a very short electronics class i took a year or so ago, the thing that mattered was the "base current" which could be at any reasonable low voltage like what I have it at in the schematic. Is this true? im just asking because i dont remember having to add any diodes to a simple transistor switch circuit. I will research this more though Again, thanks for the help! |
#4 |
some of them will burn.... so, it is safe to use a diode....it will control the voltage...you can insert 7 volts and the voltage there will not be 7 volts anymore... diode junction controls, alike a zener diode controls. Others transistors will not burn when having 7 volts there. 0.26A is a good current.... but as voltage is low (saturating voltage) you will have small heat to each fan...but using several you gonna have heat. The transistor will dissipate 130 miliwatts to each fan...installing more than one you gonna perceive some heat. In my imagination you already know those things..asking just to be sure.... about the strange diode i am suggesting to use...try to use without it. bye, Carlos
#5 |
Not safe to enter with higher voltage than this one pointed in red. regards, Carlos
#6 |
Or you could just power the fan from the +12 volt rail of the power supply.
Frank |
#7 |
the base resistor might be a bit low in value. At 12V control input the resistor has 12 - 0.7V across it. It passes 51mA to the base. A saturated transistor with a gain ~10 gives an emitter current of 510+51mA ~=560mA. With the control voltage at 7V the emitter current will be [7 -0.7] / 220 * 11 ~=315mA. What is the running current of the fan? Does it increase at start up? I'd be tempted to add a Zener or resistor across B-E to limit the Vbe at low base currents. You must ensure that the control voltage drops below 300mV to turn the transistor off and that it must change from ON to OFF to ON quickly otherwise the transistor will overheat.
regards Andrew T. |
#8 | |||
Instead, i can get the +5volt constant from the DVD drive for the base current; with this is it safe to run it directly to the base resistor? or is a diode needed? I will definitely have to research this; this sounds familiar but i know little about this but im sure its pretty simple. Quote:
I could wire the fan directly to the dvd drive harness but i dont want to under-power the dvd drive, would this be possible if i did just that? Quote:
#9 |
1V control voltage is way above the Vbe of the switching transistor.
That high signal will not allow the transistor to switch off. For 260mA of fan current, I would suggest a medium power mosFET as the switcher. It only draws current to charge the gate capacitances, none to drive the load. The mosFET needs a much higher control voltage and would better suit your ON/OFF signals. Use the same 220r attached to the gate.
regards Andrew T. |
#10 |
The 4401 might be a bit iffy in that application because its gain is on the low side. The numbers Andrew worked up look ok, but... not quite being in saturation or slow turn on/turn off could result. A couple possible alternatives come to mind. A high gain high current device like the ZTX690B is designed exactly for this type app. Just about any darlington could be used - even a TIP device or two 4401's. If a home-brew darlington is used, hang a 1 to 2k resistor from each base to ground. If you've ever gotten stuck with fake TIP142's fan/relay drivers would be a good way to use them up (been there done that bought the T-shirt). Or a mosfet could be used. Just about any N-channel will do - but don't waste an overly big or expensive one. Again, with any very high gain device, hang that resistor from gate to ground. Which is best? Depends what you already have in the parts bin.
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| switch-on, switch-off sequence for preamp/amp | cbutterworth | Tubes / Valves | 1 | 2nd March 2007 12:41 PM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| Heater switch transistor | ianl | Tubes / Valves | 4 | 23rd March 2006 01:11 PM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.11270 seconds (89.12% PHP - 10.88% MySQL) with 11 queries |
