The “VOLKSAMP”
The NAD 3020 can be summarized as the “VOLKSAMP”, an amplifier for the people just like the Beetle was the “VOLKSWAGEN”. Yesterday I decided, on visiting the town center, I should pop by the one of three swap-shops doing trade in our “one-horse town”. Usually they have nothing of real value, chip-board closets, cheap TVs and ply-wood guitars. Yesterday turned out to be my lucky day! To my utter amazement there, between Fung Cha DVD players and Sakyno “Multi-Channel” amplifiers stood a help-less little NAD 3020 with a bright orange sticker on its face. After recovering from my mild case of “luck-struck-hee-bee-gee-bees” I grabbed it for a mere $38-50! Wow! The amplifier most certainly did not belong to a loving owner. It was extremely dusty and downright filthy. After I tested it to confirm it worked I took on the challenge to make it shine again. ![]() Upon opening it up I found that someone replaced the mains transformer for some reason or another. I didn’t worry as the amplifier performed electrically as it is supposed to. The repair-man also connected the LED power indicator to the one tx-tap with a pair of resistors – reason unknown. I stripped it down completely, removing every last panel, button and screw. I then carefully removed the main PCB and prepped it to be washed with strong detergent (a trick I learnt from a key player in the local hi-fi industry!). I carefully scrubbed the PCB until I was certain all gunk was removed. The procedure was then followed a good rinse with clean, cold water to remove all trances of soap. It was dried using a ETI hairdryer (the type that can burn the hair from your head). Before I assembled the amplifier again I connected all wires to run a check on it. I also restored the LED connection to its correct place on the PCB. All was fine. Assembly was a breeze. I even managed to fit a brand new power cord with a two-prong plug for the sake of neatness. ![]() The amplifier now took residence in my main system. Its sound is punchy with great bottom-end grunt. Highs are remarkably extended but can, at times, be a bit brittle. The phono-stage works a treat with my Fidelity Research SUT and Dynavector MC cartridge. Running the E.A.R. 834P phono-stage (equipped with a Alps attenuator) into the LAB Input (which bypasses the pre-amp section) provides an exciting listening experience from the analogue source. What a great find and what a great little amplifier! The 3020 may be a budget amplifier but its sound suggests otherwise. It shows that a piece of audio equipment doesn’t have to feature a 25mm thick face-plate from aluminum to sound good. Its not the parts that you use, its how you employ it. The secret is in the design, not the styling. To the designer of the NAD 3020, I salute you! |
#3 | |
#4 |
diyAudio Chief Moderator
Does it sound like the electrolytics are still OK?
#5 |
frugal-phile(tm)
so many of these have died, it is sure nice to see one restored.
Yours has a different power transformer then i've seen. I don't know if it is a South Africa thing or yours has been replaced (the screw strip connector would tend to have me think the latter) dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
Looks great, very clean. Well done
![]() It's possbile the original transformer blew up or the person wanted a larger supply - who knows. It is probably wise to consider a full replacement of all electrolytics in the amp though. If nothing else, replace those 4 large PSU capacitors. Also, should you ever want to replace the output transistors, there is a mod you must do if you use modern 2955/3055 pairs. See the other two threads already linked by Salas. |
#7 | |
Other than that it works a charm! |
#8 | |
#9 | |
#10 | |
frugal-phile(tm)
dave
| "TECHNO"Amp building in progress-using "Iron Method" | zox2003 | Solid State | 23 | 30th March 2010 08:42 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
