What kind of solder do you guys like to use?
Old 16th May 2009, 07:08 AM   #1
Uncle Olaf is offline Uncle Olaf  United States
Default What kind of solder do you guys like to use?
Hey All,
I am new to this forum, but have been playing around with electronics for some time. Do you guys (and gals) favor a particular brand of solder? Any thoughts would be appreciated.
Regards, Jon 'Uncle Olaf'
Old 16th May 2009, 07:32 AM   #2
jaycee is offline jaycee  United Kingdom
I'm dreading my last rolls of 60/40 running out :x
Old 16th May 2009, 07:45 AM   #3
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
I use this for all my diy audio . . .
Old 16th May 2009, 08:38 AM   #4
Samuel Jayaraj is offline Samuel Jayaraj  India
I use both 60/40 as well as 2% silver stuff. The latter is a quick setting type and requires good whetting and good soldering iron. Otherwise, I have not yet picked up any sonic differences between the two.
Sam
Old 16th May 2009, 08:41 AM   #5
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Kester "44" #66/44 .031"
I've used the "lead-free" solder. I hate it.
Frank
Old 16th May 2009, 01:50 PM   #6
Stock up on a lifetimes supply of 63Sn/37Pb in various diameters, 16g to 26g.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th May 2009, 02:57 PM   #7
ostripper is offline ostripper  United States
ostripper's Avatar
Luckily , RoHS has not fully caught on here. Radio shack(Tandy) , Mouser, MCM and others will continue to sell Sn/Pb for the forseeable future.
All the RS solders are VERY good quality but a bit heavy on the rosin. Mixed with some of the copper/selenium/silver solders for plumbing,one can make a current enhancing PCB "mix" to augment rails traces for large amplifiers.
On the flip side , the new RoHS FR-4 PCB's are tougher , (traces will not lift , even after minutes) as to facilitate the higher temperatures. I put a piece under the blowtorch , the board burned away before even small traces lifted. One can rework a board 100 times and never worry about damage.
Standard 60/40 (same stuff they sold 25 tears ago)
http://www.radioshack.com/product/in...ductId=2062715
The kester page..
http://www.mouser.com/catalog/catalogUSD/638/2148.pdf
Idiot proof FR-4..
http://www.mgchemicals.com/products/500.html
OS
Old 16th May 2009, 07:34 PM   #8
john curl is offline john curl  United States
john curl's Avatar
SN62 or SN63 are OK. 60:40 is marginal, try to get a good brand of solder if possible, because of differences in age, and flux.
"Condemnation without Examination is Prejudice"
Old 16th May 2009, 08:48 PM   #9
sparcnut is offline sparcnut  United States
Another vote for Kester #44 0.031 (60/40) here. The non-eutectic mix does not bother me, you'll have problems if you jiggle the joint with any solder. The key is to have a clean iron tip and lowish temperature to avoid losing the flux too quickly. Maintain a clean tip and the good thermal contact means joints will still heat almost instantly.
I also have a half-height spool of Radio Shack solder that works fine too. It's marked "Standard Rosin Core Solder" and is also 60/40.
Old 16th May 2009, 09:22 PM   #10
john curl's Avatar
Better to use SN63, at minimum, IF you can find it. Trust me, cold joints are something to avoid.
What kind of solder do you guys like to use?Hide this!Advertise here!
What solder do you guys use? excetara2 Parts 190 13th December 2008 03:19 PM
Hi Guys! I'm one of the Portuguese Guys who love diy sapito Introductions 3 2nd September 2002 02:19 PM
What kind of solder to use? wchick Parts 17 24th July 2002 03:13 AM
Copyright ©1999-2017 diyAudio
