Old 14th May 2009, 05:24 AM   #1
Rafael L's Avatar
Default Stage output, driver oscillating
I tried to triple darligton output, but depends on the driver has oscillation with capacitive load (330nF parallel 8 ohm)
The margin phase of the circuit is ~80° (resistive load).
In square wave the most has oscillation was with the transistors MJE15032/33, with MJE340/350 and BD130/140 the response was better.
This is the circuit output:
Driver BD139/140 (330nF parallel 8 ohm).
[img=http://img21.imageshack.us/img21/5844/gr1c.gif]
Driver MJE15032/33 (330nF parallel 8 ohm).
[img=http://img21.imageshack.us/img21/8072/gr2m.gif]
What is the best way to improve the oscillation
Old 16th May 2009, 11:46 PM   #2
Rafael L's Avatar
I was simulating Zobel network without, noticed that the capacitance(330n) is very high without Zobel network.
My question is:
Which value of the maximum capacitive load, circuit does not oscillate without Zobel?
would be necessary base stopper in driver? (in simulator has not did difference)
Square wave:
Old 17th May 2009, 12:24 AM   #3
Mr Evil is offline Mr Evil  United Kingdom
Try including one or more of the driver stages in the Miller loop, as in the attached schematic.
https://mrevil.asvachin.eu/
Old 17th May 2009, 12:27 AM   #4
jaycee is offline jaycee  United Kingdom
way too much current through the predriver stage
also, 2n5401 etc is not going to be good enough. you want a high voltage high speed medium power (TO-126 ideally) device here such as 2SA1381/2SC3503
Old 17th May 2009, 01:09 AM   #5
Rafael L's Avatar
2n5401/5551 bias is 4 mA, these transistors are dissipating 135 mW. I do not think it is high for these transistors.
But I am thinking of lowering the bias in driver (22mA)
I do not use this compensation miller, in my circuit is inverting diff pair.
That short-circuit capacitor in multiplier-ratio (Attached fig) , I should use ?
Old 17th May 2009, 02:24 AM   #6
you still need miller compensation even with (especially with) this capacitor.
Old 17th May 2009, 03:30 AM   #7
wg_ski is offline wg_ski  United States
+1. The main effect of the miller cap is to install a dominant pole. Lowering the pole frequency naturally created by Cob of the vas has the side effect of pushing the poles created by the output followers higher in frequency. With a triple, that's not a luxury - it's a necessity as each stage has some phase shift. And of course, a capacitive load adds yet still one more pole to fight with.
Old 17th May 2009, 04:12 AM   #8
Rafael L's Avatar
Simulated with this capacitor, no effect with low capacitance.
But for values higher of capacitance, makes some difference
Which capacitor you say, Cdom or short-circuit Ratio?
Attached more simulations
Load 8 ohms/20nF
Frequency square 20Khz.
Base stopper output increased to 5 ohms (if I increased more, distortion increases )
Old 17th May 2009, 06:14 PM   #9
Originally posted by Rafael.luc
...Which capacitor you say, Cdom or short-circuit Ratio?..
Miller capacitor = Cdom.
You say you don't have one... is that because you are using some other type of frequency compensation, or is it a low-feedback design or something else that lets you get away without one?
Edit: Don't forget an output inductor!
Old 17th May 2009, 10:26 PM   #10
Rafael L's Avatar
[B]
I tried cdom (shunt base-emitter VAS), not did difference for oscillation square wave, the capacitor inverting diff par does compensation Miller (better for the topology which I use)
Yes, inductor solve the oscillation. But I want to know, which for value capacitive load I have on the output, 10nF/8R would be a good value, before adding the inductor ?
-Oscillation off, with inductor of 3uH in output.
Fig. Loop gain, phase margin with: Driver 2S-4793/1837, output 2S-1943/5200
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
The_P
EL84 as both driver and output stage. pwan Tubes / Valves 29 8th April 2008 09:12 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
driver stage for CFP output. RichardJones Solid State 0 21st April 2003 07:46 PM
Page generated in 0.12701 seconds (75.80% PHP - 24.20% MySQL) with 11 queries
