Hello, I need some help. I decided to replace all the electrolytic capacitors in my old -1990ish- Musical Fidelity P270 II power amp with ’better’ ones at least fresh ones. These were the ones on the main boards (dual mono design) not the big power supply ones.
I did one side, put the thing back together and tried it, everything OK. Did the other side… smoke! It was coming from a resistor -100R ceramic 4 watt- paralleled with a 68nf capacitor on an earth lead going to, or from?, one of the 4 large 10000uf’s arranged together. I realise this means little to anyone not familiar with this amp! I’ve checked everything I can think of. I don’t seem to have made any errors in my soldering etc. One thing I’ve found out is that the resistor doesn’t overheat unless the heatsink (the mono psb is on) makes contact to the rest of the amp’s body. An earth short? Where! It’s unlikely the new capacitors were faulty? (Panasonics & Nichicon) Before I start removing things any ideas at all where the fault could be!!?
#2 |
I seem to have flummoxed you!
here's a picture the ceramic resistor with the orange capacitor attached is the one overheating |
#3 |
Does anyone even know what these two components are for? a safety device?
#4 |
These form an earth loop disconnector circuit.
If they are smoking that means current is flowing. You have a power supply short to ground somewhere. |
#5 |
hello.
have you tested the isolation between transistor cases and heatsink (with multimeter ) ? |
#6 | |
the 'case' touches the heatsink with a thin plastic insulator sheet and a screw going throuh it, it must make contact? |
#7 |
dynoport
On the P270,s that I own the ceramic resistor you mention on the P270 power supply is fitted on the positive, and negative, supply supply lines between the two power supply capacitors. I assume that it is intended to make a filter. On my P270,s the ceramic resistor is 1 ohm and not 100 ohm. Don |
#8 |
There should be no conductivity between the transistor cases and the heatsink. If there is, then it means a problem with the mica insulator or some other connection.
There should be no conductivity from any power supply rail to the heatsink - the heatsink should only be connected to ground. That resistor getting hot means there is current flowing from somewhere, to ground, via that resistor. You say that it is connected via a wire near the filter caps - do check you havent got any bridging, even just a tiny flake of solder or stray strand of wire will do it. |
#9 |
the case is a TO-3p not one of those all metal ones
#10 |
Same applies. The metal tabs should be completely isolated from the heatsink. If any of them conduct, there is a problem.
| Musical Fidelity P270-2 output devices? | kenneth | Solid State | 28 | 10th January 2012 02:55 PM |
| Musical fidelity P270 and A370 fets | AMV8 | Solid State | 14 | 16th September 2011 04:40 AM |
| Musical Fidelity P270 | Lenin | Everything Else | 9 | 5th February 2010 02:44 PM |
| Musical fidelity p270 | ingemar | Solid State | 3 | 13th June 2006 06:12 PM |
| Musical Fidelity P270 | Lenin | Solid State | 3 | 24th March 2002 01:27 AM |
| Page generated in 0.08824 seconds (85.48% PHP - 14.52% MySQL) with 11 queries |
