Hi~
I'm going to build this amplifier as my project in school. The circuit designer Bert Molenkamp is also the designer of legendary Mark Levinson No.23 power amplifier. (he did mention in the introduction,but i'm not sure also =D) Specifications HPPA (power supply + / - 45 Volt (@10Amp); 4 * 64,000uF) Maximum output power: 100 Watt RMS, 1 kHz sine wave, 8 ohm 200 Watt RMS, 1 kHz sine wave, 4 ohm 680 Watt RMS, 10 kHz square wave, 1 ohm Frequency range: 10 Hz .. 250 kHz, sine wave, 100 Watt, 8 ohm (input base resistor 27k//220pF, to prevent amplifier from slewing) Slewing Rate: 90 V/uS (sine wave, f=500kHz, P=50W, 8 ohm) Damping factor: 2000 (100Hz, Ro=0.004; Rload=8ohm) (DF=Rload/Rout) 1300 (1000Hz, Ro=0.006; Rload=8ohm) 400 (10kHz, Ro=0.02; Rload=8ohm) Peak output current: 60 A (limited by fuses in PSU lines) Here's my questions: 1. Anyone build it before ? How's the sound ? 2. Is it a good design ? (specification so pro) 3. Why he use the regulator IC for the input stage ? 4. Can i use normal capacitor ? (my place hard to find MKP capacitor) I've search the forum but less information about this amp Hope someone pro can help me before i build it regard! -flacer |
#2 |
4. you can use a _bipolar_ elco if you wish
3. to get lower rails (lower dissipation in frontend), to avoid ripple bleeding into VAS... 2. maybe I'm missing something, but my short look didn't cause any sparks of enthusiasm on my side 1. dunno Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#3 |
Some more info: http://www.arky.ru/audio/shem/hppa/hppa.htm
What about this amp design ? What about this amp design ?
http://tda1541a.com The Final List |
#4 | ||
Anyway i will try to build it with electrolytic bipolar capacitor regard! Quote:
thanks for the help yes all these information i already read through the circuit diagram also from the original websitehttp://www.arky.ru/audio/shem/hppa/hppa.htm I'm interest in this circuit because he said that: "I attempted to make an amplifier that could catch up with the best transistor amplifiers in the world. My great example in those days was the legendary Mark Levinson No.23 power amplifier." LOL~! but seems less people build this amplifier previous i only build some IC base amplifier this my first solid state project just hope to gain some knowledge from who know this circuit before i start p.s. sorry English not good @@ regard! -flacer |
| HPPA Amplifier not working | flacer | Solid State | 14 | 30th June 2009 02:36 PM |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.09057 seconds (74.84% PHP - 25.16% MySQL) with 11 queries |
