#11 |
Ok, after some trial and error, I have ended up with this.
It wasn't that easy to get it to turn off fast enough. For a class-AB amp this would be no problem, as it would take some time for the PSU to loose enough voltage for it to make a plob in the speaker. The way my class-d amp it makes a noise just after the switch is turned off. For fastest turn off the trick is: - Choose C2 as small as possible. The turn on delay is determined by R2-C2. - Choose R1 as small as possible. At turn off, both C1 and C2 is discharged through this resistor. - Lower the voltage over C1 as much as possible. I have put in a zenner on 6,3 V for this purpose. The less voltage the less time it takes for C1 to discharge. C2 which determines the turnoff time, will not start discharging before V_C1 is lower than V_C2 minus Vdiode ..... Anyway with the components shown, it works quite well |
#12 |
this is a delayed turn on.
There is no instant off circuit. It waits for the charge to slowly diminish and eventually switches off.
regards Andrew T. |
#13 |
the circuit i posted had the discharge path through a negative rail, not ground......
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#14 | |
Anyway it works good enoughfor my purpose. See picture of both + 16 VDC PSU for the gate driver and the realy circuit. |
| Muting relay problem | decky | Solid State | 23 | 23rd March 2008 07:29 AM |
| Denon DCD-425 muting relay modification | blacktone | Digital Source | 0 | 9th March 2007 10:07 AM |
| muting transistor>relay,can i do this? | Rodzilla | Analogue Source | 1 | 20th August 2004 12:22 PM |
| Aleph L Muting Relay Rating | PaulyG | Pass Labs | 3 | 10th December 2002 12:55 AM |
| Aleph P 1.7 output muting relay... | Freddie | Pass Labs | 5 | 23rd October 2002 07:41 PM |
| Page generated in 0.09120 seconds (71.22% PHP - 28.78% MySQL) with 11 queries |
