#61 |
Banned
Jung type op amp regulator with different decoupling scheme, improved current source, and ZVP3310 mosfet driving Toshiba C3298 pass transistor. Waiting for AD8610 and OPA627 op amps for testing. Built on protoboard with top layer group plane. Weird parts layout for short signal path.
#62 |
Those new boards of yours look way better indeed.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#63 |
Banned
I know it's homely, don't rub it in. This is a quicky test circuit board all was built for speed (and with speed) not looks. I hope to have it running tommorow.
#64 |
Where do you get that ground plane proto board?
Could be useful for quick'n'dirty tests. Andy. P.S. Tested AD825 op-amps tonight, they are the dog's danglies in my preamp supply. They trade ultimate impedance and noise (realtive to AD797) for flatter impedance curve and better bandwidth, and sound much better to me. Musical whole just 'gels' better, more of a band, less a recording. |
#65 |
Just for Harry, here's a pic of the new boards, on the test rig.
AD817 fitted for quick test purposes, AD825 provision is underneath. Zetex transistors are substituted for the 2N2907's, in accordance with Jocko's new law Enjoy... |
#67 |
Banned
WAY COOL!!!!!!! Very nice layout. Standard Jung design with 317 preregulator?
H.H. |
#68 |
Jan,
None yet, I only built them this morning. Currently on burn-in and will measure noise tomorrow, hopefully. Other results may take a little longer, I'm currently re-designing the impedance / line rejection jig. Sonic evaluation of the first two I built, now nicely run-in are marvellous - I love the AD825, wish I could source some AD8610's, they model well. My sample request hasn't arrived ![]() Regards, A. P.S. Did you ever get my email? - I never received anything back from you. |
#69 | |
You'll make me blush
Resistors are Beyschlag and the level-shift zener is a beefier 5W part too, but that was mainly an availability issue, it doesn't need to be this big. Apart from that it's the same... A. |
#70 |
Banned
Don't be modest. I love the 45 degree orientation for the small transistors. How about photo of the bottom side. Great part choices, the Rubycon ZAs are new and simular to the Sanyo oscons I think. Very nice job. There are several oscon ( Organic SemiCONductor type caps on the market now.
http://www.low-esr.com/compare.html-ssi http://www.vishay.com/products/capacitors/aluminum.html http://www.sanyo.com/industrial/comp...scon_home.html http://www.rubycon.co.jp/english/prodct/new2.htm http://www.chemi-con.com/mapresults.php?series=fa http://www.panasonic.com/industrial/...ef_xr_1201.pdf |
| reducing voltage | rtill | Solid State | 28 | 16th January 2009 01:45 PM |
| Reducing regulator noise. | Predator864 | Power Supplies | 3 | 23rd March 2008 07:26 PM |
| Low Noise 3 Leg Voltage Regulators | dsavitsk | Parts | 2 | 10th July 2007 02:49 AM |
| Reducing PSU Voltage | hernanstafe | Parts | 1 | 9th March 2007 05:14 PM |
| Best way of reducing heater voltage? | showdown | Tubes / Valves | 14 | 20th July 2006 07:15 PM |
| Page generated in 0.11323 seconds (77.01% PHP - 22.99% MySQL) with 11 queries |
