#111 |
Heh, I'm waiting for the first guy to jump in and say "jwb -- you are a huge moron!". I just don't understand electricity before I've had my first cup of coffee. I should remember that before I start typing into this little box.
I shall try to redeem myself. C3 and R3 form a <em>high-pass</em> filter, not a low-pass. They ensure DC stability below 11HZ The op-amp is internally compensated, we don't need to worry about HF stability. |
#112 |
OK, If I have a very, very clean +-12 volt DC supply and I need to pull it down to 8.5 to 8.9 volts DC should I use the 1086 and 1186 as I already have these or is there a Zener that will set the output in the range stated above. Thanks
#113 |
since there is interest in these things from time to time, here is YALNR.
Courtesy of Maxim (so you know who's chips it uses http://a330.g.akamai.net/7/330/2540/...es/62305di.pdf (last two pages) |
#114 |
Account Disabled
Pretty ordinary - appears dominated by the op amp noise which is > 4.5nV/sqrt Hz.
Hi jwb, have you considered a nested FB loop using 2 op amps to find some gain at 25MHz. Only the first needs to be ultra low noise. If it's commercial I may let you use my integrator nesting concept which has been patented by others but I have established prior art. Is DC drift of the reference a concern? Greg |
#115 |
Hi Andy,
I'm sorry to bother you in this old thread. I've just found this thread. In Your Post #20, Is it possible to improve this regulator by adding a small cap multiplier on NE5534 pos supply to replace R2 & C2 network? pINO
pINO |
| reducing voltage | rtill | Solid State | 28 | 16th January 2009 02:45 PM |
| Reducing regulator noise. | Predator864 | Power Supplies | 3 | 23rd March 2008 08:26 PM |
| Low Noise 3 Leg Voltage Regulators | dsavitsk | Parts | 2 | 10th July 2007 03:49 AM |
| Reducing PSU Voltage | hernanstafe | Parts | 1 | 9th March 2007 06:14 PM |
| Best way of reducing heater voltage? | showdown | Tubes / Valves | 14 | 20th July 2006 08:15 PM |
| Page generated in 0.08599 seconds (73.64% PHP - 26.36% MySQL) with 11 queries |
