Old 10th May 2009, 12:16 PM   #11
taj is offline taj
taj's Avatar
Fascinating. That Acoustic blue is certainly familiar (I'm showing my age here). As I recall, Acoustic amps were typically MI (musical instrument) amps, bass in particular. This one looks like it was made to be versatile with the input jacks on the front and the back. Use it for bass, keyboards, PA, whatever.
Sakis is right. 2-ohm ratings were unheard-of back then, but 4-ohm amps were not uncommon for PA since they were typically expected to drive parallel 8-ohm speaker cabinets. But if it's spec'ed for handling 2-ohm loads, so be it. Maybe it was just ahead of its time.
If the amp turns out to be ugly sounding, which I would certainly expect, that heatsink tunnel is certainly recyclable! Chassis too I suppose if it's refurbed a bit.
..Todd
Old 11th May 2009, 04:23 PM   #12
d0n is offline d0n  United States
Originally posted by Steve Dunlap
The collector seems to be right. That amp was rated at 275W@4 ohms and 375W@2. That was at 5% distortion. This was a PA amp that listed for $899 in 1977.
5% distortion!
Thanks for the info.
Old 11th May 2009, 06:09 PM   #13
wg_ski is offline wg_ski  United States
..Todd
Back then, and amp wouldn't have been given a 2-ohm rating unless it could run at 1/3 of its 2-ohm sine wave power indefinitley. Go buy any pro amp nowadays and they can't do that at 4 ohms, let alone 2.
Old 11th May 2009, 06:25 PM   #14
sakis is offline sakis  Greece
sakis's Avatar
Default it is actually amazing
how many people bother to answer this ....
we know exactly how much power this amp makes ....only the OP has no means to find this out .... but any way ...i go from this now
thank u
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 11th May 2009, 10:20 PM   #15
Default Re: it is actually amazing
thank u
thank you for your wonderful and well though out post. It was a big help!
Show me your guts! neurot Car Audio 106 21st April 2012 06:51 AM
AD797 guts aparatusonitus Solid State 3 21st March 2008 05:02 PM
Amp Guts Page is Up!! Matt74 Car Audio 5 2nd November 2005 02:56 PM
Car amp guts page Matt74 Car Audio 7 30th September 2005 04:14 PM
spraying the guts of my amp... 9am53 Tubes / Valves 2 20th April 2005 01:25 AM
Page generated in 0.09662 seconds (74.82% PHP - 25.18% MySQL) with 10 queries
