Power transformers versus amplifier output power..what is your option?
Old 8th May 2009, 08:40 PM   #31
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Paulb... this is a very good idea!
Thank you.... i will manage to try a capacitance multiplier using zener diodes. (36V plus 12 volts in series)
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 8th May 2009, 09:32 PM   #32
paulb is offline paulb  Canada
You're welcome Carlos.
For those interested, here's Rod Elliot's version of the capacitance multiplier:
http://sound.westhost.com/project15.htm
Old 8th May 2009, 11:08 PM   #33
Default I have tested minutes ago.... i had too much voltage drop
now testing the electronic regulator.... will test tomorrow to see how long it wii accept short circuit into the output,,,,will install more power transistors in paralell and will let the system heat up for a couple of minutes,,,, short from positive to ground and from negative to ground simultaneously.
Why that monster behavior?
Safety!.... amplifier can burn,....,shorts can happens into power amplifier board (this happens sometimes when hard used, bad cooled or too much low speaker impedance),.... fuses can fail to open the circuit.... then overload can short the series pass transistors into the electronic supply....this happening will send 80 volts to the amplifier circuit..... well.... i want to avoid this mess beeing sure the regulator will survive, even shorted for a couple of minutes.
The electronic stabilizer circuit (output voltage adjustable) will keep the voltage pre adjusted within 10 percent.... also allow you to adjust perfectly... so you can adjust 50123 milivolts to the positive and 50123 milivolts negative if you decide to to this way... when transformers never has, absolutelly, the same voltage.
Carlos
Old 9th May 2009, 02:02 PM   #34
Default I have tested a modified electronic supply...more transistors into the output
And i had positive regulation...ahahahahah!...very good that..when you enter the load the voltage increases in the place to decrease.
Difference of voltage, under load (regulation) from positive rail to negative rail is less than 1 volt when you adjust to 50 volts the output..when 2.27A each rail load enters, then the voltage increases to 52 volts in the place to decrease.
I have also made tests using lower voltage..around 35 volts..and current was 5 amperes each rail.... also i could have positive regulation.
Well... camera battery is charging..soon i will upload to youtube and then will post a link here.... so you will be able to see.
The supply was tested 20 seconds with a short circuit.... to see if it will burn output transistors... was fine.
Also heat is fine because input voltage descends...drops under load..so..power over the series pass transistors are not so high.
The current under short circuit i could not measure.... maybe i can, using low ohm resistance (shuntO. and measuring voltage...but for sure is very high...hummmm...maybe 50 amperes under short...or more than that... voltage zero and very high current because of short.
Well..movie will show you.
regards,
Carlos
Old 9th May 2009, 03:09 PM   #35
Default First video uploaded to youtube about transformer and supply
http://www.youtube.com/watch?v=ocVA90cPUhE
soon you gonna have the link to the other one, where the voltage was adjusted to 50 volts.
The supply works fine till we reach 55 volts..then the voltage starts to drop and regulation goes bad... at 60 volts the voltage drop goes to 15 percent.
regards,
Carlos
Old 9th May 2009, 03:11 PM   #36
The supply works fine till we reach 55 volts..then the voltage starts to drop and regulation goes bad... at 60 volts the loss goes to 15 percent.
regards,
Carlos
Old 9th May 2009, 03:50 PM   #37
Default The second one
http://www.youtube.com/watch?v=PW7jfHCuIbI
regards
Carlos
Old 9th May 2009, 06:02 PM   #38
Default What i have to tell you folks
I have made testings:
My first assumption was thinking the vbe multiplier capacitance existent into my circuit could could filter without using big condensers (big capacitance values) into the supply...i was wrong...we need that capacitance..no way... when sucking amperes the noises appear..the filtering into the electronic power supply helped a lot...but could not fix.
My second assumption is that i would not need too much speed to correct voltage errors.... the error amplifier could work without problems because was a reasonable transistor... wrong once again!... speed was a problem.. i have perceived into the sound reproduction... the attack was strange...had a delayed decay but had a decay.
This approach, this supply, this idea, will not fit even a class A amplifier where you have not too much current variation..say..starts high and continues beeing high... comparing maximum power current into class A amplifier to the stand by current results in smaller number compared to the division of maximum current by the stand by current into class AB amplifiers.
This one, with electronic regulator, at least this one, cannot be used with class A amplifiers too because of filter size...the idea was to use small filter after rectification..but this do not works...the electronic supply cannot make the miracle i was wishing.
This is what happened folks..i will continue with my buzzer transformer playing good sound till i have better transformer to replace.
regards,
Carlos
Old 9th May 2009, 06:23 PM   #39
Bigun is offline Bigun  Canada
Bigun's Avatar
Can you include a notch filter to the amplifier front end, maybe too complicated and bad for sonics ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Power transformers versus amplifier output power..what is your option?Hide this!Advertise here!
GU-50 100W output and power transformers Wavebourn Group Buys 48 15th March 2011 06:34 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 03:20 AM
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 03:57 PM
Power Transformers in Output! mod_evil Tubes / Valves 17 25th May 2006 09:31 AM
Copyright ©1999-2017 diyAudio
