How to find the size on a fuse to "Soundstandard MA3600" ?
Old 6th May 2009, 03:03 PM   #1
k2teknik is offline k2teknik  Denmark
Default How to find the size on a fuse to "Soundstandard MA3600" ?
Do somebody have a "Soundstandard MA3600" or a manual/schematic for that ?
I have lost the fuse and do not know the size, both in mm, A and speed.
Old 6th May 2009, 10:43 PM   #2
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
hello,
15A for the rail fuses standard blow. Hope this helps.
regards,
audiomachines
Old 7th May 2009, 02:53 PM   #3
Thanks for your reply.
15A, does it go for at 230 Volt version af the amp. ?
Any idea about size, 5*20mm or 6*25mm ?
Old 8th May 2009, 12:45 AM   #4
hello,
15A standard blow per rail @+/-110 Vdc, if you are referring to the AC fuse (primary side of the toroid) 20mm 15A standard blow for the 220VAC version if fitted with NTC as a soft start circuit 20mm 15A slow blow if not fitted with the soft start circuit (older version), 20mm 30A for the 110VAC versions. Hope these helps.
audiomachines
Old 8th May 2009, 02:43 PM   #5
Yes that is the one, the one I can change from the outside of the box.
20mm 15A standard blow for the 220VAC version if fitted with NTC as a soft start circuit 20mm.
15A slow blow if not fitted with the soft start circuit (older version).
Hope these helps.
That is just what I needed, thanks a lot.
BTW, the first 15A fuse blowde up on the first power up (The amp had been without power for more than a year)
I tryed a 10A and it stay alive and the amp was working, but apperently only in one channel.
We only had a subwoofer to test on, and it has 2 input and 2 output.
I try to swap left/right input, but only sound i left channel.
The led over the input att. lit on left channel with one cabel to speaker, and with 2 cabelt from amp to speaker both led lit.
Selector on back set up for "stereo".
Is this subwoofer to tricky to use as a test-speaker ?
/Hans
Old 8th May 2009, 03:31 PM   #6
hans,
does the protect led stays lit on the right channel? if it does
you may need to check the rail fuses inside the amplifier, it is located on power supply board near the filter caps. Be careful the rail voltage is quite high +/-110VDC, a total of 220VDC and the filter caps can retain the charge for a quite period of time.
If all rail the fuses are ok, then you may need to check the input board for crack solder joints (where the XLR jack, TRS jack, OP Amps are mounted) and check also the slide switches, you may need to spray them with some contact cleaner.
that amplifier is rated at 600W per channel at 8 ohms, 1200W at 4 ohms, 3600W in bridge mode into 4 ohms.
regards,
audiomachines
How to find the size on a fuse to "Soundstandard MA3600" ?Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
My first "nice" thrift store find... wboyd Solid State 3 26th October 2007 08:57 PM
Where can I find NPC digital filter chip "SM5843A" aht Digital Source 12 18th March 2005 07:56 PM
Which stuffing material to increase "perceived" enlosure size? Two Moons Multi-Way 4 6th January 2002 05:27 PM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Copyright ©1999-2017 diyAudio
