Old 5th May 2009, 07:57 PM   #1
qsa is offline qsa  Germany
qsa's Avatar
Default replacement for Bidirectional Switch MBS4991 and Triac 2N6346A
Hello have a problem for finished crowbar in NMOS Amplifier,because Devices obsolete,
ONSEMI told me MAC228A4G is replacement for Triac 2N6346A
but for Bidirectional Switch MBS4991 no way, we can offer only SIDACs, it looks like there are no Biderctional Switches offered by our competitors as well. Check with TI as far as I know they might have some stuff to offer
Does somebody have idea for replacement Bidirectional Switch MBS4991 with todays devices ?
regards from Germany
Old 7th May 2009, 12:47 AM   #2
nigelwright7557's Avatar
Default Re: replacement for Bidirectional Switch MBS4991 and Triac 2N6346A
Look up 4016 and 4066 bi lateral switches.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 7th May 2009, 02:12 AM   #3
wg_ski is offline wg_ski  United States
Default Re: Re: replacement for Bidirectional Switch MBS4991 and Triac 2N6346A
Doubt it very seriously. Those are logic gates, and won't work outside the supply rails.
What's needed is a small triac with a pair of inverse-series zener diodes in the gate. Tie the zener string to MT1 or MT2 to make a 2-terminal device. The zener voltage (plus about 2V) will be the breakover voltage. You'll have to dig up an old data sheet to find out the typical breakover voltage for that particular device.
Old 7th May 2009, 04:10 AM   #4
Enzo is offline Enzo  United States
One of my OEMs uses crowbars across the outputs of their power amps. They used to use SAC187 triacs, which are about the same as the 2N6346, but have moved on to more modern types. They used to use the SBS14/MBS4992, but in more recent designs in place of the SBS, they have a pair of SCRs 2N5064 in back to back parallel with their gates connected together. Gates connected to nothing else, just each other.
CD4066 Switch replacement 405man Parts 7 21st November 2009 05:28 PM
b&k st-140 toggle switch replacement thezaman Solid State 0 29th May 2008 02:57 PM
Need a Triac zedrider Parts 1 28th September 2007 04:38 PM
SCR or TRIAC? Wombat2 Parts 3 6th June 2006 04:21 AM
triac's used as crowbar?? hugobross Solid State 19 12th August 2002 05:02 PM
Page generated in 0.09375 seconds (74.20% PHP - 25.80% MySQL) with 10 queries
