Old 4th May 2009, 09:45 PM   #1
Default AB outputstage
hi ...
i am studying electronics and have been given the objective by my lector, to design am amplifier with an class AB output stage to give about 150W at 8 ohm, with a quiescent current of 50 mA.
I want to use a Vbe multiplier and because of my output transistors i need a Vbb of at least 2.8V
so how should i do that... i just cant figure it out...
i thought i came to a solution with R2 = 3.3K, R1= 1k, and Iref = 2.5 but something is wrong... the Quiescent current i not at all 50mA... !!
What am i doing wrong ?
Old 4th May 2009, 11:30 PM   #2
Four diodes (or diode strapped transistors) in series?
Laugh, but its the same parts count as the resistors....
Or you can diode strap ONE mosfet gate to drain,
and VGS-On might have about the right voltage.
But MOSFET temperature coefficient may bend
the wrong way for this application.
Maybe there is an LED with your voltage?
Old 5th May 2009, 07:37 AM   #3
AndrewT is online now AndrewT  Scotland
is that 50mA of quiescent current, the total for the whole amplifier? i.e. front end quiescent current + driver bias + output bias?
regards Andrew T.
Singel Mosfet outputstage. Baard Pass Labs 5 29th May 2004 10:17 AM
What outputstage should you use with PCM1704 Ryssen Digital Source 0 6th January 2004 05:20 PM
Tube outputstage Ryssen Digital Source 8 17th December 2003 03:58 PM
Page generated in 0.08458 seconds (62.66% PHP - 37.34% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
