Old 4th May 2009, 09:45 PM   #1
kees52 is offline kees52  Netherlands
Default new amp total mosfet
hi there
I have design this amp, through pass laps idee for drive with conventional mosfet for power.
so lets try it, it is simulated so not everything is exact.
distorsion is 0.005 in smulation.
greetz
Old 4th May 2009, 09:58 PM   #2
Mr Evil is offline Mr Evil  United Kingdom
One problem stands out to me: You've use MOSFETs to make a current mirror (Q2/6/8), which doesn't really work very well because they have quite variable Vgs, which means the output current strongly depends on the particular devices used. If you want that to work, you will have to match the FETs, and you will also need some degeneration resistors.
Furthermore, the output current will vary with the supply voltage because the current is set only by the voltage across R4. You can improve that by connecting a capacitor across Q2 drain to the supply.
https://mrevil.asvachin.eu/
Old 4th May 2009, 10:16 PM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally posted by Mr Evil
One problem stands out to me: You've use MOSFETs to make a current mirror (Q2/6/8), which doesn't really work very well because they have quite variable Vgs, [...snip...]
I tried and fried; can post a picture of hole burnt in a chair by 10W 1Ohm resistor that unsoldered itself and fell down.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 4th May 2009, 10:23 PM   #4
49 - for the 16th time
c2cthomas's Avatar
Good thing that hot resistor hit the chair!
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 4th May 2009, 10:35 PM   #5
Wavebourn's Avatar
Thanks! I would see it as soon as starts smocking!
Old 4th May 2009, 10:56 PM   #6
It started wearing a dress?
Old 4th May 2009, 11:25 PM   #7
Wavebourn's Avatar
I have no clue. I saw it already in the hole in the chair after Diana Krall stopped singing abruptly.
Old 5th May 2009, 02:12 PM   #8
Hi all
here a changed one, lets see wat I have did wrong this time haha.
The new css more potential..
Old 5th May 2009, 02:12 PM   #9
here the specs
now it is simulation need some corrections when build.
the new ccs has be calculated and will be oke, or minor correction.
I have also a hybride these works and play in my room.
Old 5th May 2009, 10:15 PM   #10
CBS240 is offline CBS240  United States
CBS240's Avatar
Clearly a victim of "simulated brainwashing" wrt the power device input stage and the attempted mosfet Wilson mirror.
Total Newbie here!Some help please! mudpuppy Multi-Way 3 11th November 2007 02:12 AM
How many amps in total? Sweetrobot Car Audio 0 26th June 2006 05:37 AM
total newbz0r judey Introductions 1 6th June 2005 03:30 PM
Total Impendance? amoeba86 Multi-Way 4 26th November 2003 01:58 AM
Total newb here WindChill Introductions 5 9th September 2002 12:06 AM
Page generated in 0.09905 seconds (79.62% PHP - 20.38% MySQL) with 11 queries
