Old 4th May 2009, 04:15 PM   #1
Default Bogen CT100 speaker hookup
I'll be using a Pioneer 5 disk CD player, two 50 watt 8ohm speakers and this Bogen CT100 amp to play cd's at my sisters retirement. How do i connect the speakers to this amp please.
Regards........Tom in Kentucky
Old 4th May 2009, 11:29 PM   #2
Speakerholic
Cal Weldon's Avatar
Bump.
Tom, let's just use this one thread to find a solution.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th May 2009, 11:37 PM   #3
Speakerholic
Cal Weldon's Avatar
Tom, I have emailed you a pdf of the manual.
Old 4th May 2009, 11:43 PM   #4
ted is offline ted
Since this is a mono amplifier –
For both 8 ohm speakers in parallel, connect to (gnd and 4) screw terminals. If using both 8 ohm speakers in series connect (gnd and 16).
The wire connect to the 8 ohm screw terminal, don’t worry about. I think it is used if the speaker connecters on the left side are used instead of the screw terminals.
Old 5th May 2009, 02:12 PM   #5
Default Bogen speaker connections
Thanks for all your quick responses. I get it........
Regards......Tom
Hookup wire Buzzy Solid State 6 4th July 2008 01:39 AM
Autocostuire AD-CT100 hannoy63 Class D 3 7th February 2007 02:19 PM
best hookup wire inside a speaker spwal Multi-Way 8 5th January 2007 05:26 PM
computer/speaker hookup buschdiver Everything Else 3 11th December 2005 02:19 AM
Sony speaker hookup problem fenixviper Multi-Way 1 8th March 2005 01:59 AM
Page generated in 0.06379 seconds (83.77% PHP - 16.23% MySQL) with 10 queries
