I've got a Rotel RX550 solid state integrated amp, it's over 20 years old and has been by my side since then. When I turn the volume knob, it sounds scratchy, and sometimes one channel will drop out until I move the volume knob again. I'm wondering if I should try taking it apart and cleaning out the pot? Let's just say it was in a rather smoky environment in college...
I absolutely love this amp and would like to get it back to running well. The LED display gave out long ago, but I don't really care about that. |
#2 |
You can try to clean the pot with a good electronics cleaning spray...there is a good one mentioned on this site but the name escapes me. Just don't use something like WD-40. I bought a can of cleaner/lube at Radio Shack that has worked ok in some instances. However, the pot's contact surfaces may be completely worn out by now, which means replacing the pot with a similar unit may be required.
Also, the amp probably uses fuse lamps, not LEDs. These are most likely very easy to replace. You just have to pull one out to figure out the values. |
#3 |
this unit is probably stressed quite hard ...... you might consider your shelf a recaping and also a few upgrades ...
take look at this you might find it usefull vintage amplifier repair and upgrade manual
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
| Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player | Staykov | Digital Source | 5 | 16th May 2012 12:24 AM |
| Rotel RX-830 | awpagan | Solid State | 11 | 17th March 2009 08:39 PM |
| Rotel RC-850 Pre Amp + Rotel RB-870BX | bleachershane | Analog Line Level | 4 | 9th February 2009 11:20 AM |
| Rotel RA-921 Repair help. Its for a good cause | filholder | Solid State | 5 | 13th April 2005 02:33 PM |
| Help - need to repair Rotel RCD 930ax | sanjivs | Digital Source | 0 | 9th February 2004 10:09 AM |
| Page generated in 0.07969 seconds (81.49% PHP - 18.51% MySQL) with 10 queries |
