Banned
I have a question here, I think Carlos (destroyer x) will be able to answer because he has an AKSA.
The question is, can you burn an amplifier if the earthing arrangemets of the two equipment you're connecting are different? I read a post that an AKSA amp which uses star earth was connected to a double insulated or different earth scheme and it burnt. Also I would like to understand the problems which can arise from various earthing arrangements. thanks |
#2 |
Nope.
No matter which Earthing system has been used (Class1 or Class11) the equipment remains compatible. If it did not, then the manufacturers would have millions of failed returns under warranty.
regards Andrew T. |
#3 |
Banned
so the worst case scenario is humming noise?
or perhaps safety issues? |
#4 | |
This is a timely thread. My questions is about multiple trafo's , do you connect the CT's of 2 or more to the same main star ground ?
With 3 different chassis grounds (heatsinks on hinges) I have a lot of green wire... on big supply) and 1 on the main chassis. Quote:
.OS |
#5 |
I have tried and given up using centre tapped transformers for multi channel power amplifiers. I can never get rid of measurable hum (0.2mVac to 0.6mVac) on the outputs.
regards Andrew T. |
#6 | |
regards Andrew T. |
#7 | |
Banned
could you please explain to me how this might arise when connecting equipment together each with different grouding schemes? |
| Driver Shelf Clearing | Timn8ter | Swap Meet | 14 | 14th September 2008 07:04 PM |
| Clearing Inventory- Stuff For Sale! | needtubes | Swap Meet | 9 | 11th July 2006 07:40 PM |
| Clearing my capacitors - Oscons, Simlics, Fine Golds... | Ruach | Swap Meet | 0 | 12th October 2005 03:43 AM |
| Page generated in 0.08981 seconds (70.22% PHP - 29.78% MySQL) with 10 queries |
