Hi, I was wondering if this op amp is running at unity gain? I know with just the two 22k resistors it is. But with 3, I don't know. Anyone have some insight?
Thanks Scott |
#2 |
It’s an inverting summing amp with two inputs (it basically adds the two signals together and inverts). For inputs of +1V & +1V you get –2V at the output. For inputs of +1V,-1V you get 0V at the output, +1V & 0V = -1V, and so forth.
#3 |
Yes, it's a unity gain opamp.
The gain at each input is set by the feedback resistor divided by the input resistor. In both the inputs, the gain is 22/22 = 1 As Kaos has said, the opamp ADDs all the input signals. You can put on as many as you like
regards Andrew T. |
#4 |
Thanks, I understand now.
| Confusion: NFB, OLG, Unity Gain | corrieb | Solid State | 32 | 9th October 2010 01:57 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 02:30 PM |
| Unity Gain (AV=1) Zen Amp | LS | Pass Labs | 2 | 16th September 2004 05:40 AM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 02:47 AM |
| Page generated in 0.06867 seconds (70.28% PHP - 29.72% MySQL) with 11 queries |
