Hello,
A few years ago I purchased from DIYAMP.net a totem pole amp. It is a GRSlone design. On this board is a terminal block point called a Intergal Overload Output. What am I supposed to hook it up too? It is driving me crazy. I looked through the books, searched, queryed and no answer or response. Can anyone help? Does this go to a ground of some kind. Here is a snapshot of the schematic section showing how it ties into the amp board then runs off to a ground symbol. What is that something?? |
#2 |
Here is the picture of the amp board showing the terminal block actual location.
#3 |
It looks like a protection circuit (hense the name "overload output").
Even that some parts of the schematic is missing, my guess would be that Q13 detects overload and pulls Q23 On, which gives a positive output on the IOL terminal. This may have connection to an external protection circuit........
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#4 |
My guess is that it connects to an LED which lights up when the VI limiting kicks in; just a guess.
Sam |
#5 |
Hi!
I have talked to Randy Slone about the IOP output. Material on a Bluray or DVD can cause high level transients to overload the amplifier. Accumulated activations (2-3 /sec is normal and false) eg. 100 times / sec is abnormal and the IOP circuit will short the drive signal. You must connect the IOP output terminal to the Fig. 8.5 AUX-board ('The Audiophiles project source book'). Solder it to the point between Rin and BR1. The IOP circuit will drop-on the muting relay to disconnect the speakers. I am finishing my totem pole amplifier, working now with the cabinet. I have not testet the IOP circuit yet. I hope it will work out fine! Vid |
#6 |
Could you please PM me Randy's contact mail id etc., I want to contact him on a more personal note, to continue from where we left off last time. By the way it has nothing to do with audio. Thanks.
Sam |
#7 |
#8 |
1965GTO - Have you tried connecting the IOP terminal to the AUX-board?
Vid |
| Page generated in 0.08402 seconds (77.70% PHP - 22.30% MySQL) with 10 queries |
