Old 30th April 2009, 07:49 PM   #1
Rafael L's Avatar
Default Use of diode in projects M-Levision
What is the reason designer of the Mark Levision using many diodes in their projects.
Would be for thermal stability?
Or only voltage drop?
That schematic has quite diodes across the amp:
http://www.audio-circuit.dk/images/s...23-pwr-sch.pdf
Old 30th April 2009, 07:54 PM   #2
The one and only
Nelson Pass's Avatar
Perhaps the designer was being paid by the part.
Old 30th April 2009, 08:01 PM   #3
Artie is offline Artie  United States
Diodes are a cheap and easy way to produce a voltage reference. 1 diode drop is roughly 600mv's. Where you see 2-in-a-row, would be approximately 1.2 volts. 4 would be 2.4 volts, and so on and so forth . . .
Old 30th April 2009, 09:44 PM   #4
Rafael L's Avatar
Or leave the amp more difficult, to anyone copy
Old 30th April 2009, 11:36 PM   #5
Rafael L's Avatar
I know that diodes are used as reference voltage, current sources for example, generally is used one or two diodes.
For voltage drop could use a resistor metal film that would give the same result
Old 30th April 2009, 11:48 PM   #6
blueskynis's Avatar
Send a message via MSN to blueskynis Send a message via Yahoo to blueskynis
But putting a bigger resistor would increase LTP gain and therefore possibly making amplifier less stable. Diodes have low Rd (in order of ten ohms) and they do not alter gain so much, they only shift DC value. Maybe they are also used for thermal compensation also...
EDIT: Ohh, I didn't noticed more diodes on other pages...well I don't know why the designer used so much diodes...
Windows-free with Linux
== blueskynet.dyndns-server.com ==
Old 1st May 2009, 04:43 AM   #7
cbdb is offline cbdb  Canada
Looks like most of these diode chains are voltage refrences. (voltage level shifters). Diode voltage drops are not as dependent on current changes as resistors. This helps with the power supply rejection ratio. And I think regular diodes are less noisey than zener diodes.
Old 1st May 2009, 04:41 PM   #8
Rafael L's Avatar
Look the picture attached, there are two diodes to drop VBE in output stage (class-B),to a greater bias simply increasing the number of diodes, would be better that resistors?
Old 1st May 2009, 10:52 PM   #9
Adding another diode is too large a voltage jump, thats why most use Vbe multiplier wich lets you dial in the exact amount of bias. The main reason diodes or transistors are used to bias the out put is so the bias becomes temperature stable. These diodes are mounted right on the out put tranies or on the heat sink so they are the same temp. these diodes do not have the same purpose as the other diode chains. the other ones in the above cct. are V refs for the current sources.
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
Run out of Projects Irakli Everything Else 2 12th December 2007 12:40 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
8 Ohm projects?? bbksv Multi-Way 2 11th January 2004 01:13 AM
Page generated in 0.09305 seconds (80.69% PHP - 19.31% MySQL) with 11 queries
