I wanted to entitle this: "Bonnie Baker Reveals All" -- but I do read her column in EDN religiously -- some reasons that you single-supply amp may sound better when used in Inverting mode:
http://www.edn.com/article/CA6651590.htm.html |
#2 |
No opamp at all is better.
There are 2 advantages of opamps: 1. no DC shift 2. High efficiency Since they are used with coupling caps the 1'st one is out. Second one may be traded off for sound quality in power amps, or absolutely have no meaning in preamps since their power consumption are nothing against what power amps consume. However, there is the 3'rd advantage: imaginable simplicity of design that is melting down as soon as you design something better than can be bought in the nearest store.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Well if you can get away with an inverting configuration then you do not need a rail-to-rail input opamp.
I don't know of any common "audio" use opamps that have rail-to-rail input stages either. |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| whats the difference between inverting and no inverting | mikee55 | Parts | 1 | 7th January 2007 10:36 PM |
| Aleph Phase Inverting / non inverting | macka | Pass Labs | 9 | 22nd February 2006 07:01 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 06:53 PM |
| Inverting/non-inverting Op-amp Inputs !!!help!!! | IIR | Solid State | 17 | 11th May 2002 02:02 AM |
| Page generated in 0.07431 seconds (67.42% PHP - 32.58% MySQL) with 10 queries |
