Old 29th April 2009, 01:32 AM   #1
Artie is offline Artie  United States
Default LME49811 front-end for Gilmore amp?
I was all set to start gathering the parts for the Gilmore headphone amp, when a little research showed that acquireing the dual-matched JFET's, (2SK389/2SJ109), might be harder than I expected. (Amazing amount of drama surrounding those parts.)
So, can I use the new LME49811 chip to replace the front-end of the class A output section? Kinda like this:
Will the 9ma max output of the 49811 be sufficient to drive the pre-drivers? I realize that the output-stage gain is less than unity, so the chip will need to run from a higher voltage.
Just not sure if its this simple.
Thanks all.
Old 29th April 2009, 09:17 AM   #2
Anyone?
Old 29th April 2009, 09:39 AM   #3
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
If your drivers has a Hfe at 50, then they can put out >400mA to drive the output devices which is more than needed.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 29th April 2009, 09:41 AM   #4
AndrewT is online now AndrewT  Scotland
Have you deliberately swapped the drivers?
You can replace the 389/109 pairs with 170/74 discretes.
Buy matched pairs or match them yourself and then thermally couple the pairs.
Cin>=1.4 * Ci * Ri+Rs / Rin >= 1.4 * 10 * 57k8 / 1k8 >=450uF
Ci could be reduced to 1u5F or 2u2F and still pass sufficient bass.
Cin @ 10uF will kill the bass response.
regards Andrew T.
Old 29th April 2009, 04:10 PM   #5
Hey Andrew. I'm not exactly sure what you're asking me here. The right side of that schematic, (with the green resistors), is straight from Kevin Gilmore's drawing. The left side is straight from the 49811 app note.
I like the idea of using the 170/74 subs, but I thought those were discontinued also.
Thanks for the input cap info. I'll see if I can locate the 170/74 subs.
Old 29th April 2009, 07:56 PM   #6
nelsonvandal's Avatar
You can find matched quads at amb.org. I think you can find them matched at borbelyaudio.com as well.
When using LME49811, I don't think you need the discrete gain stage, just emitter followers, double emitter followers, CFP or something like that.
Old 29th April 2009, 08:00 PM   #7
Electrons are yellow and more is better!
peranders's Avatar
The left transistors did form the VAS stage so you can't use this. You have to make them emitter followers instead. Otherwise it might work.
/Per-Anders (my first name) or P-A as my friends call me
Old 29th April 2009, 08:36 PM   #8
Thanks again guys. (Gals?)
I guess this just brings me back to the idea that I should just build it as it is, before I go messing around with "mods" that I'm not sure of.
LME49811 + Sanken STD03N/P jackinnj Chip Amps 33 8th November 2011 03:08 PM
Class A with LME49811... Dxvideo Chip Amps 22 2nd November 2009 01:11 PM
Need help with a Gilmore Jr. build ALustyGhost Instruments and Amps 4 3rd November 2008 02:35 PM
Kevin Gilmore stottie Solid State 1 30th November 2006 07:37 AM
Gilmore amp troubleshooting name773 Solid State 10 31st August 2003 04:44 AM
Page generated in 0.10770 seconds (78.79% PHP - 21.21% MySQL) with 10 queries
