Old 28th April 2009, 10:58 PM   #1
Domid31 is offline Domid31  France
Default LME49830 burning
Hello,
I am working on a Mos amp using LME49830 and IRFP240/9240
I have already burned many mos, I do not understand why.
Sometimes it burns when powering up, sometimes I can run long time at full power, output is clean, no oscillation.
I am using National application circuit, with my own PCB (there is no mistake on it). Gate resistors are 100 ohms, I did not mount the 12kohm resistor between the 2 gates (Rq in National application), I just add 2 zener diodes between gate and S for mos protection.
When the amp burns, the gate resistors are getting black, the mos and the lme49830 are dead.
I am using a +-50V unregulated power supply, large capacitors (33 000uF).
Any Idea ? Can it be caused by the zener protection diodes ?
Can it be caused by power supply rise (full voltage can be applied on mos before lme49830 because of PCB design) ?
I am a bit lost ...
Old 29th April 2009, 07:44 AM   #2
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Hi Domid,
Does your output bias current level adjustable like in the datasheet? And did you measure the bias?
Did you hear any "shaking" noise while your MOSses dieing?
Best regards,
Ozgur
Old 29th April 2009, 03:03 PM   #3
Hello,
I have setup to bias current to 70 mA in hot condition.
I am monitoring it: run the amp, wait some minutes, cut input signal, measure and adjust bias.
the bias temp compensation is not used for the moment.
Can this destruction be caused by zener diodes in between gate and source ?
Can it be because I have no resistor between the 2 gates ?
I do not know. I'll replace the burned parts, and test it again.
Old 29th April 2009, 03:28 PM   #4
AndrewT is online now AndrewT  Scotland
you must fit a gate stopper resistor to each and every gate lead.
This resistor does it's job better if it is place right on the gate lead with the shortest possible lead length.
regards Andrew T.
Old 29th April 2009, 03:29 PM   #5
Dxvideo's Avatar
Dear Domid,
That MOSFETs should have at least ~20v GS voltage limit. So I think, without any input signal its not possible to reach gate voltage limit to kill them.
But; If youre not using a gate resistor for these MOSFETs then you have a big situation! Because, its strongly possible that they will start to oscillate after a short time! I think this is the reason you lost a lot of MOSFETs...
Vbe multiplier solution for bias stability is not a must for this amplifier but its a recommendation. Because as I see in my LM4702+Lateral MOSFET amplifier, they have very good bias stability against temperature..
However I think 70mA is a bit more for IRFPs... 40mA will be sufficient for best distortion results..
Let me know the results after gate resistors added..
Best regards,
Ozgur
Old 29th April 2009, 03:33 PM   #6
Default FET bias
for best distortion and sound quality results the higher the better for bias current. just keep on increasing it all the way up to ClassA bias.
Borbely recommends a minimum of 500mA of bias for the whole output stage and a minimum of 150mA for each output FET.
regards Andrew T.
Old 30th April 2009, 06:32 AM   #7
Dxvideo's Avatar
Default Re: FET bias
Wrong!
Look at the AN-1645... They have already tested 4 diffrerent MOSFET types and determined different bias levels for each.. And for IRFPs the best bias value is 25mA, not 150!
Thats what I meant in my last posting..
Best regards,
Ozgur
Old 30th April 2009, 07:30 AM   #8
I prefer to accept Borbely rather than National's application note.
I trust him more than the design team.
regards Andrew T.
Old 30th April 2009, 08:42 AM   #9
Dxvideo's Avatar
Ok... Thats your choice. But Nationals application note is dedicated for LM4702-LME498XXX series..
So I prefer (and already used) that bias levels and gate stopper values for this series amplifiers only.
Best regards,
Ozgur
Old 30th April 2009, 08:52 AM   #10
Dxvideo's Avatar
Default Re: LME49830 burning
Ooops... I have missed that you already have gate stoppers! So the oscillation theory is dead.. As mentioned, its too hard to kill your mosfets in this application by the reaching of gate voltage limit.. I would remove the zeners and test the amplifier with inputs muted.
Best regards,
Ozgur
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 115 27th October 2007 05:50 PM
Page generated in 0.11052 seconds (74.31% PHP - 25.69% MySQL) with 10 queries
