Old 27th April 2009, 06:26 PM   #1
Havenwood's Avatar
Send a message via MSN to Havenwood
Default suggestions - Amp Fig11.12 (Slone)
Hi!
What think about this modification?
The amplifier is in Randy Slone, pag 368 (Figure 11.12)
The amplifier works, but I thinkThe VAS is not ok
Iq is very very small (nV or pV on 0.1ohms)
What say about this?
Here the simulation:
http://www.megaupload.com/?d=2FHZYHTY
With MultiSim10
- Music by John Williams -
Old 27th April 2009, 06:47 PM   #2
blueskynis's Avatar
Send a message via MSN to blueskynis Send a message via Yahoo to blueskynis
I think it will not work very well. Because of use of current mirrors in LTP the standing current is ill defined in VA stage. There are numerous threads about the problems that arise when using current mirrors in symmetrical designs. I remember G.Kleinschmidt was trying to use current mirrors in his symmetrical designs.
Edit: Have a look here
Unstable VAS current in amp from Slone book
Windows-free with Linux
== blueskynet.dyndns-server.com ==
Old 27th April 2009, 07:10 PM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Yes, you have to scrap the mirrors and replace them with resistors to define the bias in the VAS. Try about 680 Ohms. Also a small emitter resistor on the VAS transistors may help.
All the trouble I've ever been in started out as fun......
Old 27th April 2009, 07:23 PM   #4
blueskynis's Avatar
Also, how could mr. Slone publish his book with those big mistakes?? Even I noticed mistakes in his designs and I am not an expert.
Old 27th April 2009, 10:06 PM   #5
homemodder's Avatar
This design is bad, Slone realised his mistake, he has a newer version of the amp called optimos, this is a very good solid design, sounds darn good and is powerful. Worth a build.
Old 28th April 2009, 12:53 AM   #6
Havenwood's Avatar
Hi
blueskynis, what is LPT?
CBS240, ok, I will try simulate with the resistors R=680 (ie) in diferential transistor in the input stage.
VAS cascode is an option? like this:
Schematics:
http://www.pcpaudio.com/pcpfiles/pro.../Vag/etapa.pdf
from PCPAudio
Thanks!
Old 28th April 2009, 01:37 AM   #7
Banned
Havenwood,
the input stage cascode should have its own Vref /current source.
Old 28th April 2009, 02:26 AM   #8
GK is offline GK  Australia
Default Re: suggestions - Amp Fig11.12 (Slone)
There is nothing to bias the VAS.
See here for one solution:
http://users.picknowl.com.au/~glenk/K12A.HTM
Old 28th April 2009, 03:24 AM   #9
Havenwood's Avatar
Default Re: Re: suggestions - Amp Fig11.12 (Slone)
thanks for the link!
Very interesting
Old 28th April 2009, 06:19 AM   #10
CBS240's Avatar
Hi
Schematics:
from PCPAudio
Thanks!
Hi
What is the purpose of the pots that source the cascode zeners?
The base of the Vbe multiplier should not be tied to the wiper, but the pot should be between the base and emitter. If the pot fails open (quite common) the outputs will fry.
Has anyone here built a Slone Amp or a Tigersaurus? EE_Mark Solid State 94 10th December 2011 03:56 AM
Slone 11.4 questions... Flavio88 Solid State 4 31st January 2007 01:08 PM
Randy Slone JDDCo Solid State 6 22nd September 2006 02:57 AM
Randy Slone: Opti-MOS pixie Solid State 73 12th September 2004 07:57 AM
Mosfet amp problem, Slone amp 5th element Solid State 14 22nd March 2004 11:03 PM
Page generated in 0.10134 seconds (80.85% PHP - 19.15% MySQL) with 11 queries
