Old 26th April 2009, 10:18 PM   #1
Default Pioneer SA-6500II - Balance problem?
Hi all,
I have an old Pioneer SA-6500II amp, and the left channel is really soft and a bit crackly sounding. I've never repaired an amp before, but I'm handy with a soldering iron (having repaired various things before... VCRs, fluorescent lamps... game consoles... computers...) and I hope someone who's been around the block can step up and help me out.
I'm guessing that the problem is with the balance knob, fiddling with it seems to somewhat improve the problem temporarily. I opened the case, and looking inside, the balance knob is the only one mounted on the PCB with legs. (Everything else is connected by wires... damnit! Just my luck!) and it seems to be composed of two potentiometers linked with a single knob shaft.
What should I do to troubleshoot before I go to the trouble of getting the board out of there and desoldering the pot...?
The balance knob is right in the middle of the picture. Sorry for the obscured view, it's hard to get a good angle.
Old 26th April 2009, 10:40 PM   #2
nigelwright7557's Avatar
Default Re: Pioneer SA-6500II - Balance problem?
The balance pot will have a value on the side of it.
Use this value to buy another one.
It is a dual potentiometer.
I wouldnt mess around cleaning it as once they are worn they are useless.
Sorry cant help with suppliers in Canada but I am sure a search will find someone who sells them.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 26th April 2009, 11:34 PM   #3
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
clean the pot(s) first.
almost always, on these types of equipment the pot's the problem ...
Old 27th April 2009, 12:12 AM   #4
I sprayed some jig-a-loo into the pot and torqued it left and right a few times. It started to feel much snappier and smoother and checks with the ohm-meter revealed it to be working correctly, so I resoldered it and lo-and-behold the amp works fine now!
Thanks tommt, I guess you've seen this before! Thanks for lending me your experience
Pioneer DV-355 PS problem Bud Digital Source 21 6th December 2009 09:08 PM
Pioneer SX-838 problem b17man Solid State 2 13th May 2009 11:57 AM
Sonic Impact balance problem? nukegoat Class D 9 21st September 2007 07:45 PM
Pioneer PL-200 Problem tuwhitt Analogue Source 1 12th September 2007 07:24 PM
Balance problem - room layout??? JDeV Everything Else 3 22nd September 2003 06:36 PM
Page generated in 0.08226 seconds (74.08% PHP - 25.92% MySQL) with 11 queries
