Hey, so I've built an amp with a Gainclone and a small op-amp based headphone amp inside.
The Gainclone runs off a bipolar +/- 35v supply. Using LM317 and LM337 regulators I created an +/- 18v supply to power the headphone amp and other preamp gears. This hooks up to the bipolar 35v supply. Now, what I want to do is have a switch to select the output. How should I go about doing this? I don't want to use one of the outputs and have the other idling, I want to actually turn off the circuit not being used. Can I disconnect V+ or V-? Will that work? Do I need to disconnect both? I'm afraid I may be limited by the number of poles I have to switch with. If I get a DPDT, I need one pole to switch the input and then the other switch would need to somehow control the power supplies. Any ideas? Thanks! |
#2 |
Use an SPST switch and add two relays. One DPDT power relay (e. g. Omron G2R-S) for the power supply to switch V+ and V- and a small signal relay (e. g. Omron G6K) for the two input channels. That keeps the different potentials apart and allows for short paths.
The G2R-S is available with built-in suppressor diode. You have to add one to the G6K.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
When switching sources in a pre-amp, what is the best option for wiring up the relays?
Using G6K should I use one relay to switch both signal and ground of a single input, or would it be advisable to wire all the signal GNDs together and only switch the signals? (one relay for 2 signals?) Any concerns about the latter approach? BR, Lars |
#4 |
Mmmmk so I'm doing this right now. Is this going to present a significant current drain on my transformer? I've got 2 relays for signals and a heavier duty one for power switching.
Is there a more efficient (power wise) way of doing this that anybody could suggest me? Thanks! |
| Using headphone amp as speaker amp | hugz | Headphone Systems | 1 | 18th July 2006 02:08 PM |
| Connecting a speaker to a headphone jack | Gambit | Multi-Way | 1 | 22nd August 2004 06:56 AM |
| converting car speaker wires to headphone jack | PantSeatFlyer | Car Audio | 19 | 13th February 2004 09:56 PM |
| Headphone out from Speaker out | IanBaxter | Headphone Systems | 1 | 13th January 2004 06:26 PM |
| My first (headphone) amp! | daxy | Headphone Systems | 1 | 13th March 2003 08:55 PM |
| Page generated in 0.08592 seconds (71.88% PHP - 28.12% MySQL) with 10 queries |
