Old 20th April 2009, 03:48 AM   #1
sl-15 is offline sl-15  United States
Default Help with Hafler Pro1200
I recently got a used Hafler Pro1200 power amp. It worked fine and sounded good but there was loud popping sounds when I turned it on and off.l opened it up and discovered that one of the big output caps was loose on the board, I could pull it out with my hand. So I soldered it back in. Now the popping sound is gone when turning it on and off. While taking the amp apart I further discovered two resistors that look fried. (see picture). I measured both of them and they read 37.4 ohms. The manual tells me that these two resistors should be 47 ohms 1/4W 5% carbon comp.
Here is my question: Should I replace them with the value stated in the manual or should I replace with the value that I measured? I have no idea why these are fried, only know that both of them are in the same position in the signal path but one is for the left the other one for the right channel. They seem to still work but I was wondering if it makes sense to put a resistor in that is rated for more watts.
I recently build two Bottlehead kits and am familiar with soldering but am totally new to electronics. So I have no clue what these resistors do in the signal path and how they affect the sound.
Any input is highly appreciated.
Thanks in advance.
Old 20th April 2009, 05:01 PM   #2
This is my first post here and I was not able to load the picture (jpg) to my above post.
I can load it fine on the bottom of the edit window put then it does not show up in the post.
How would i get this to work? Thanks
Hafler Pro1200 MOSFET subs IFixAudio Parts 1 5th April 2009 04:35 PM
2SK1056 MOSFET for Hafler PRO1200 IFixAudio Solid State 0 27th March 2009 04:14 AM
Hafler 9130/Pro1200 circuit differences? reiver Solid State 1 26th May 2008 04:29 PM
hafler amp or pre-amp larryg Solid State 2 9th March 2004 10:39 PM
Page generated in 0.07590 seconds (64.86% PHP - 35.14% MySQL) with 10 queries
