Elliott Sound - "The Project 3A" - Page 3 - diyAudio
Old 26th April 2003, 12:37 PM   #21
Rudy is offline Rudy  Belgium
might i suggest a little different circuit for the biascurrent, becous in this situation you will not have any quasy current, or you have to many quasi current, couse of the high current gane in the output circuit it wil be very unstable and inpossible to know what it will do.
Greetz Rudy
Old 26th April 2003, 07:29 PM   #22
Account Disabled
which part - that i need to change ?? - show me..... u mean medium -transistor stronger?
i will us in that amp for PA.... i have a transformer 48~0~48 2000VA for 2 che' .... and i us in 4 fan - 12V
Old 26th April 2003, 08:01 PM   #23
Account Disabled
sajti - if i change all the MJE340-350 to MJE15030/1
in the circuit it will change something????
Old 26th April 2003, 11:00 PM   #24
no not the transistors, they are fine, you need to replace the 2 diodes D2, D3 with a little circuit, and make sure when you power the thing on that the middle connection of the potentiometer is conncted to the topside ( in the drawing ofcourse ) so that the transistor ( who must be connected to the same heatsink as the power transistors ) reduces the idle current to zero. Then slowly turn the potmeter around until you find yourself a descent bias value.
Good luck with your amp btw
Greetz Rudy
Old 27th April 2003, 01:44 PM   #25
Account Disabled
i dont understand..... i can edit my pic of the P68 amp.... and make the change there...?!
Old 27th April 2003, 02:02 PM   #26
Send a message via AIM to Mattyo5
DJ, just take out those 2 dioids, D2 and D3 and replace them w/ that circuit that was posted. I don't see any other changes you'd need to make...just trying to clarify what the other guy said.
-Matthew K. Olson
Old 27th April 2003, 02:24 PM   #27
Account Disabled
i understanding now.....
but... if i will us in 70V +/- i need to replace the dioids...?
and if i us in 55V +/- i dont need to change nothing....?
Old 27th April 2003, 02:55 PM   #28
50 ..75V rail doesn't matter ( for this), its the output stage that is changed and thats why you better use that.
I myself advise that you go for a rail voltage below 60V, 75V is a lot for this amp...
Greetz Rudy
Old 27th April 2003, 03:21 PM   #29
sajti is offline sajti  Hungary
DJ,
I have no good news for You MJE15030/031, are not very good instead of MJE340/350. With lower current the MJEs have lower B. They are ideal driver devices, but not ideal as VAS stage.
Try to get some MJE340/350. They are cheap, and common everywhere. (I live in Hungary, and I have 100 of them...)
Sajti
Old 27th April 2003, 03:24 PM   #30
With 48-0-48 tranformer You will get some +/-65V for Your amplifier. It's OK.
Just replace the two diodes, with the mentioned bias regulator. (Important! Put the bias regulator transistor to the heatsink of the output devices! BD139, os MJE340 OK for this stage. ) Withg this circuit You can safely adjust the bias current, and there will be no thermal runaway.
Sajti
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 06:51 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
How to get rid of "CKK" Sound on "turn off" riotubes Parts 0 25th November 2006 04:50 PM
Can anyone suggest the "best" 300B SE sound quality schematic for a beginner like me? calico88 Tubes / Valves 42 18th July 2006 03:33 PM
Thiele-Small R_ms (mechanical losses) vs. "precise" sound? capslock Multi-Way 7 16th September 2002 10:32 AM
Copyright ©1999-2017 diyAudio
