Hello, I'm new here and here is my question. I'm not sure if I have a Super Rev 2, it does not say 2 on the unit and I can't find the manual. The serial # is 01506DM. I use this pre-amp to drive a Bryston 4B amp which drives my JBL woofers. I started getting a hum in the right channel, so I tried to determine the cause. Checking and swapping cables, I think I narrowed it down to the Super Rev. I was fiddling with the AC cord that goes to the power supply box, when I unplugged it and then plugged it in again, a pop came from the speaker and I fried the woofer. I've since then bought a new woofer on e-bay but until I solve the pre-amp problem I'm afraid to hook up the woofer. I have a multi meter tester so I checked to ac voltage, it seemed O.K. How do I check the power supply and the main line outputs on the pre-amp?
any suggestions, Thanks Greeen |
#2 |
sadly. Carlos |
#3 | |
It says preamp, so please switch off your poweramps before doing such things again Not much help though Oh, maybe try with some cheap speakers first, just about anything could be used, might not be anything wrong at all |
| Superphon Revelation MK II PreAmp | yeoldestereo | Solid State | 60 | 28th March 2012 02:32 PM |
| FS: Superphon Revelation...needs a fix | JoshK | Swap Meet | 7 | 10th February 2009 01:46 AM |
| Buzzing Superphon DM200(s) | kirk57 | Solid State | 2 | 1st December 2008 03:42 PM |
| A Revelation! | Horizons | Car Audio | 4 | 25th October 2008 03:55 AM |
| Modifications for Superphon Revelation Dual Mono | kirk57 | Solid State | 3 | 1st May 2008 01:44 PM |
| Page generated in 0.07263 seconds (70.22% PHP - 29.78% MySQL) with 10 queries |
