#11 |
Another one and for 14 euro's I would not even expect it to work
I might even order one just for fun.
http://tda1541a.com The Final List |
#12 |
Hi all,
managed to get a few minutes and hooked up the amp for some testing. The pictures are quite poor sorry about that. Also see pictures attached the crossover distortion is actually worse IRL, the pictures make is look smoother for some reason. any how I've added a picture at 1khz one at 20khz and a picture of the top and bottom of the board, if any one is interested. Overall apart from the crossover distortion, the responce was better than I expected, I have not listened to the sound yet at all as it is late so I will post again when I do get a chance to play some tunes thru it. FYI PSU is a 25-0-25 toroid. and nothing on the board got hot at all during the 10 minutes of testing, testing was done at low power (2-3 watts) out one channel only. Load was only 12 ohms. |
#13 |
output at 20khz, about 15v peak to peak approx 5v RMS
#14 |
Bottom of PCB
#15 |
TOP of PCB
#16 |
At 2 watts into 12 ohm hmmmm.....
#17 | ||
They are definitely fakes. They're using the Fairchild type package, Sanken-style laser marking, and calling them "Toshiba". |
#18 |
I suspected class B bias is the case.
All the trouble I've ever been in started out as fun...... |
#19 |
I wanne buy
#20 |
Really?
One could easily out do this circuit, even with a "blameless" circuit on vero-board. There is more than enough knowledge on this site to suit.
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Windows MP3/song player that caches whole song in RAM before playing | Daveis | Digital Source | 10 | 2nd October 2007 03:37 AM |
| Protection of Mosfet Amps from input Overdrive... | Workhorse | Solid State | 21 | 22nd June 2005 03:57 PM |
| Page generated in 0.09551 seconds (78.72% PHP - 21.28% MySQL) with 11 queries |
