Old 17th April 2009, 09:56 PM   #1
rtill is offline rtill  United States
Default hybrid will it work?
will this hybrid work? Don't need it to be class A or anything,just wanna know if it would work.
Old 17th April 2009, 10:06 PM   #2
nigelwright7557's Avatar
Default Re: hybrid will it work?
Bias cct is very poor.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 18th April 2009, 12:18 AM   #3
I just want to know if it would work. .....
Old 18th April 2009, 12:20 AM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Yes, until the idle current control pot looses contact, for example if you want to adjust the current. Think how would you change it so when it looses it's contact bias voltage jumps to zero instead of jumping to maximum.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 18th April 2009, 12:26 AM   #5
I use this cct for a MOSFET output transistor bias.
Old 19th April 2009, 04:29 PM   #6
I will try your bias design! Thanks. Any idea of what the output would be? I calculate about 100 watts at 8 ohm.
Tube Hybrid Shunt Regulator ... will this even work? dsavitsk Tubes / Valves 8 19th July 2009 09:50 PM
OB 3-way Hybrid ctrevith Multi-Way 16 27th March 2009 10:25 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
To make work/ better this hybrid sound? rick57 Multi-Way 39 20th April 2005 01:34 AM
Hybrid+ From Digilander doesn`t work ralf Tubes / Valves 1 1st February 2002 10:58 AM
Page generated in 0.07341 seconds (82.71% PHP - 17.29% MySQL) with 11 queries
