Hello. I need Your help. Today I disassambled friend's HK AVR 347 Reciever to prepare it for some tweaks, which was planned for tomorrow.
When I satrted to search all the caps I should change, I was Stunned - I saw some resistors in place where service manual describes capacitors! Here is scheme and that "caps": ![]() So how it was: 1. I'm reading service manual, seing "c507 - 330pF ceram. capacitor" 2. Searching c507 on board. 3. See marking "c507" on board, but it is resistor there! 4. Closed my eyes and try again, but FAIL again! So, PLEASE explain me, whats happening. I haven't repaired or tweaked solid state amp before, so maybe I just didn't realize something and this is normal... I haven't photos now, I will share them tommorow. But it's VERY important to have answer as fast as posible... Thank You. |
#2 |
They are small capacitors looking like resistors. Don't worry.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
Thanks. I though about this, but they looks like resistors, so I was very shocked.
Then, If it's ok, I would like to disscuss on this scheme at all. I'm planning next replacing: C637, C632 to Panasonic FC 220uf c562 Elna silmic II 100uF c607 - Silver Mica I'm intersed on purpose of next caps (If it worth changing on some better cap): c507 - if it just cap to remove some RF noise? c572 - ? c567 - just for Mute operation and not important for SQ, right? c682 - ? P.s. I'm also will be pleased with some another advices on tweaking this scheme. |
#4 |
hello.
the numbers in the schematic are not easy to read........ input c507 attenuates rf c 572 compensation against oscillations - sensible part c 567 for muting,not in the signal path c 682 looks like a part of a protection circuit. if the electrolytics 10 years old and more perhaps you can change them all ..........panasonic fc/fm and so are a good choice i think....... for the cap in the feedback leg (c 142?) i would use a nonpolar elcap................. greetings............ |
#5 |
#6 |
#7 |
thank you,now i can read the numbers...........
c 562 is the number of the feedback cap. foto: c507 (yellow-green) looks like an axial ceramic cap....o.k. if you like to experiment with sound: input elcap c502 can be changed to a 10uf high quality elcap......or you can bypass it with a foilcap............. greetings............... |
#8 |
Yep those green resistor lookalikes are really ceramic capacitors. I guess they use these because they are easy for pick-and-place machines to handle.
If you really wish to swap, change them for silver mica or polystyrene |
#9 |
I concur: yes, they look like 1/8W resistors, but are in fact capacitors. I have seen this before in the most unlikely place: a super Nintendo cartridge. The silkscreen said "C__" not "R__".
Maybe someday they will make ICs that look like resistors, too.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig |
#10 |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| What resistor should I use? | Rob11966 | Tubes / Valves | 1 | 2nd March 2009 09:52 AM |
| Why this resistor? | Shel-e-bean | Everything Else | 28 | 4th August 2006 04:57 AM |
| Help with Resistor Please | saabie22 | Parts | 5 | 2nd February 2005 09:39 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| Page generated in 0.12089 seconds (81.14% PHP - 18.86% MySQL) with 10 queries |
