I've salvaged a transformer from an old non-working receiver I found and it tests ok, measuring 90vac across the two main secondaries(each is 45VAC measured to the center tap).
The rear panel states the power consumption is 490W/870Wmax, and the mains input fuse is 5A. How do I determine the VA rating of this transformer? -Joe |
#2 | |
Inrush considerations also are a factor.. mine will blow a 10amp fuse with no softstart. A commercial 1500Va trafo is rated 1548W (below), so I suspect you have a 800VA trafo. http://www.antekinc.com/AN-15450.pdf In scale , my "unknown" 1500+VA toriod uses a 10A fuse. OS |
#3 |
Well for starters we know that it is less than the max values shown on the back panel, and less than the 5A x 120v = 600w in all probability.
The proper method is to put a resistive dummy load on the secondary and watch for a 10% drop in the secondary voltage compared to the unloaded secondary voltage. This would be a good rating for "continuous duty" - assuming the transformer can do continuous duty... The VA rating is then computed by figuring the ohms law given the value of the resistor and vdrop across it. That's pretty much it. You'll need some hefty power resistors to do the job. You might be able to fashion something up using nichrome wire from a toaster or some other heater element... but they tend to vary resistance with temperature, but that might get you in the ballpark. _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#4 |
There are 2 options of designing transformers: or loss (usually 10 percents) or overheating that is the difference between maximal allowed temperature of the transformer and an environment temperature that your equipment may experience. Usually well optimized transformers have max overheating on the power corresponding to 10% loss, so you may load it gradually and measure.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 | |
Thanks for your replies. I've been thinking about them.
How could such a (higher rated) fuse protect the gear that follows? -Joe |
#6 | |
To avoid this, it is normal practice the use a fuse about three times higher rating. There are many downsides to this practice. Using a soft start circuit allows much a smaller fuse to be used and gain the added protection available with close rating. A fuse is there to prevent you setting fire to your house. It is not there to save damaging an already faulty piece of equipment.
regards Andrew T. |
#7 |
#8 |
does someone have the data to update the graphs in that 1964 paper to cover toroidals
regards Andrew T. |
| How to determine if class G/H? | tktran303 | Solid State | 21 | 4th September 2008 11:48 AM |
| How to determine Q from a graph? | JoeBob | Parts | 4 | 13th November 2004 04:12 AM |
| Transformer VA Rating vs. Current Rating | JhonDoe | Chip Amps | 45 | 5th June 2004 01:11 AM |
| How do I determine what this Transformer is? | wotan2525 | Solid State | 5 | 21st March 2003 05:34 PM |
| how to determine the pin layout of NPN or PnP? | tone | Solid State | 3 | 31st December 2002 01:15 PM |
| Page generated in 0.17423 seconds (44.62% PHP - 55.38% MySQL) with 10 queries |
