I have to admit, to confess, that i am feeling myself bored with so many folks asking me what is the best amplifier. I do not know!…I am still searching for it. No one knows, because this is subjective, individual… there’s no two persons that feel alike, listen alike, taste alike and so on. People is always searching for privileged informations about Aksa…. I will not tell you a single word…or… will say something is public, and that means nothing, or half of nothing. What makes an amplifier good: Correctly biased..all transistors operating into their best points respecting it’s datasheet..voltages, currents, and the most special…VBE Electrolitic capacitors that are not inverted No transistor too much hot, thermal noise Not too much stages..each one distorts A good supply, the one you can suck all the current the amplifier needs into 2 ohms loads and no noise will come from the supply…just that..put 8 hertz and turn oscilator volume up…turn amplifier volume up and no mains noise can be heard… have noise?.. increase filter capacitance..ready..now a good amplifier! Wants sound stage… use two supplies..this is the best way to have good separation, and as consequence sound stage…or buy trick amplifiers, very well designed and developed…the only one…Aksa 55….only this brand produces special sound stage….and I have built and listened more than 4K amplifiers..and this happens because a trick used…not even dead I will tell you…. If you think I told you..be sure I was fooling you. ALL AMPLIFIERS ARE GOOD…ones less good when too much complicated into the audio patch..not the surrounding parts…. Say..too much stages…double differential..special differential with too much transistors, trick fets and so on…to be good they must ONLY be working fine..say..voltages and levels not wrong..and this is not hard to obtain…so… those complicators of course will be frustrated..for sure they will. The good amplifier, or the best…is the one you have, the one you built..the one you select, the one you bougth, because YOU is an important subject…EGO… selfpride You can believe your amplifier is the best one…the same way you think your wife is the most pretty woman..and she is not..this is only pride and the natural need we have to fool ourselves…also your son and daugther are not the most clever ones…you feel this way because you want..this makes you feel good..so..go dreaming! If you believe special stripped capacitors sounds..them install some into your amplifier…. The sound will not change..but you will perceive something changed…you have made your mind…so be happy with your illusion and buy more stripped capacitors. What makes an amplifier special..some tricks…I know only one… Aksa….. and I can make any wide world amplifier sounds alike… i know the tricks..will not tell ya… What makes an amplifier sound better than others…. The speaker does that..your mind does that…power does that. What makes an amplifier produce better sound stage…. Heheheheh. What makes an amplifier punchy…. Big condensers into audio patch and feedback line….bit condensers into the supply..and your mind you have made it in advance. Boys..now a days I am searching the no good ones…as the best one i could not find..only the best one to sound stage….. nothing more now I am having fun testing schematics…to discover the one is real bad..and understanding what makes them bad. What do you think makes an amplifier good, or special. Post your ideas here… agreements and disagreements. Boys..do not ask me what is better…. I do not know..ahahahha. Mine amplifiers are better!!!..ahahahahahah! Carlos .................................................. ............................................... All amplifiers sounds reasonable, or nice, if not defective! It is hard to find one that sounds really terrible (Evolution) .................................................. ................................................ I am good cooking fellows... and having girl friends.... those things i know how to do better than average ![]()
Try to build an amplifier folks ... it is pure adrenaline! |
#2 |
very active into the forum, they think i know the misteries of life. I do not know...and worse...i could not find someone to tell me what is the best amplifier...and prove that! No one has answered me basic questions about life, death, and how to understand women...no one knows. If you know something about the best audio amplifiers (yours naturally!), tell us. Post here! regards, Carlos .................................................. .................................................. ...... ![]()
#3 |
I'm not sure I agree to that it's subjective. I think the best amp is the one that adds or subtracts the least. If you add the amp to the signal path (with a "smart" dummy load) and can't hear any difference, it's perfect.
#4 |
and that's the main question...do we perceive? regards, Carlos
#5 | |
Midlife amp crisis biting again? |
#6 |
All the good sounding amps sound different, not one is better over the other, in a synergistic system one will sound better/best over the others.
There is no pot of gold at the end of the rainbow. That is why I don't build many amps of the same kind eg solid state. I build only solid stae, tube and D-class, to me there more differences among these genres of amps. |
#7 |
I am more than mid age...i have 58 years old. ahahahaha! Carlos
#8 |
the best.... maybe the better to yourself..subjective, personal. regards, Carlos
#9 |
define 'best'
best sounding, well what sounds best to you may not to someone else... best engineered...may not be best sounding.... best measuring? which measurement? I could go on and on.... |
#10 |
doesn't it depend also on the speaker ?
I mean, depending on the speaker the choice of amplifier may be different, even for the same listener. And doesn't it also depend on the music. I remember auditioning a KRELL system once. I heard 'glare' on the violins and didn't like it. But had I been listening to heavy metal I may have been really impressed.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| New best wide world headphone amplifier | destroyer X | Headphone Systems | 151 | 9th September 2006 04:54 PM |
| Page generated in 0.12614 seconds (80.42% PHP - 19.58% MySQL) with 11 queries |
