I think my cyrus power amp may have come faulty. Last night it was ON but not playing music, and a large "thump" from both speakers came out. After that i get a Yellow flashing light (the manual says its dued to DC voltage detected at the output). I opened it up, doesnt seem to have nothing blown up...don't know where to start looking and checking. Maybe someone can give me some directions? Its the Power amp, i believe the first one they made. Thank you a lot Filipe |
#2 |
Output power transistors, and probably collateral damage from that.
#3 |
Can they be replaced by an enthusiast with a soldering iron?
anybody can give a chime on the part numbers? Also, if they blew, maybe the cause of failure is somewhat prior to that, which would lead to another blew if all I do is replace the transistors. How can I measure where is the cause? Anyone here with experience in cyrus power blew ups? Thank you |
#4 |
I took a deep look into the board, it all seems to be SMD resistors, dont know if they can be changed if necessary.
Transistors look to be accessible but i would have to desolder some joints from input and output wires in order to remove the PCB from the case. If anyone can help here, i would venture but otherwise, i think it will rest in the closet. Shipping it back and forth to cyrus audio for a repair would probably be more expensive than its used value. |
#5 |
Sounds like one of Cyrus's newer amps. Sorry, but that's out of "enthusiast with a soldering iron" territory im afraid
| Cyrus 1 power transistors | Fleetwood Max | Solid State | 7 | 11th August 2009 12:57 AM |
| Cyrus 2 power switch? | voltrax | Solid State | 0 | 17th March 2008 03:47 PM |
| Mod Cyrus II power train for PSX? | enthusiastor | Solid State | 20 | 27th June 2007 03:35 PM |
| cyrus one - on/off power button | viva14 | Solid State | 3 | 29th March 2007 06:16 PM |
| Page generated in 0.07694 seconds (71.10% PHP - 28.90% MySQL) with 10 queries |
