Old 10th April 2009, 07:33 PM   #1
Bernhard's Avatar
Default Would it be nice to have constant current on the output transistors ?
No current swing = less distortion ?
Old 10th April 2009, 07:55 PM   #2
How were you thinking of doing this?
Old 10th April 2009, 07:58 PM   #3
Bernhard's Avatar
I mean in theory, would it be... ?
Old 10th April 2009, 07:58 PM   #4
Frank Berry's Avatar
No current swing = no output power.
Frank
Old 10th April 2009, 08:01 PM   #5
Doesn't Nelson do this in his Stasis amplifiers?
Old 10th April 2009, 08:02 PM   #6
Bernhard's Avatar
Please somebody could answer my question.
Old 10th April 2009, 09:12 PM   #7
Bernhard's Avatar
Same question from me > three years ago
const. voltage & const. current on output FET ?
Just made a circuit that keeps the current swing of the gain device around 10mA @ a bias of 1,1A.
I would like to implement constant current in a circlotron.
Old 11th April 2009, 04:20 AM   #8
fotios is offline fotios  Greece
fotios's Avatar
IMHO the main beneffit that offers a CCS it is the absolute rejection of the power supply ripple remaining after the reservoir capacitors, which in practice translated in better "hum" rejection. It is ucefull from the input stage up to the voltage gain stage because the common emitter arrangements.
I had an idea in the past (maybe like your?) to buffer each output transistor from the supply rail with another one (same) transistor, like in cascading form. After experimenting, the result was a loss of p-p voltage arround 5V in output, thus reduction of power, in the same time time that i had not any improvement in output noise.
Fotios
Old 11th April 2009, 05:41 AM   #9
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I did that as well, many times, from line drivers to power amps. Also, I kept both current and voltage almost stable.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 12th April 2009, 09:49 AM   #10
Bernhard's Avatar
I tried it now in a simulation with a circlotron that has distortion cancellation.
After adjusting the X resistor, THD figures stay exactly how they were around -123 dB for +/-10V swing..
constant current source hacknet Solid State 19 13th March 2006 02:46 PM
constant current sources... cathode_leak Tubes / Valves 10 29th March 2005 10:18 PM
Aleph+Constant current sources X-ZEN stefanobilliani Pass Labs 46 18th January 2005 02:53 AM
Constant current PRBS Pass Labs 6 24th March 2002 12:49 PM
Page generated in 0.10100 seconds (76.99% PHP - 23.01% MySQL) with 10 queries
