Old 10th April 2009, 07:27 PM   #1
dsavitsk's Avatar
Default Suggestions for high current CCS?
I am in need of a constant current source that can put out about 250 to 300mA and that can operate while dropping minimum volts across it -- on the order of 4 to 5V or less would be great. I am currently just using a LM317 with a RESISTOR which works, but I am sure something else will work better.
I'll use these in several places, but in particular I need to supply a 5V 250mA TUBE filament and I have 9.5VDC to work with. I'll also need it for a shunt regulator that feeds a circuit that needs 15V at ~150mA from a ~20V supply.
Any ideas?
http://www.ecpaudio.com
Old 10th April 2009, 07:36 PM   #2
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Shunt.
Old 10th April 2009, 07:44 PM   #3
Salas's Avatar
Isource. The R5 and DC meter are to simulate the heater. You connect the heater instead of R5.
Old 10th April 2009, 08:00 PM   #4
Mr Evil is offline Mr Evil  United Kingdom
Depletion mode MOSFET. They are very simple to use - just short the gate to the source, like a JFET current source, optionally with a resistor to set the current. You will probably need to cascode it to keep the power dissipation down unless you can get a big enough one.
https://mrevil.asvachin.eu/
Old 10th April 2009, 08:21 PM   #5
dsavitsk's Avatar
Originally posted by Salas
Shunt.
Thanks. R1 sets the current?
Besides the filament one, I'll use the others in an update to this project: Differential TDA1543 based NOS DAC
I've used the 10m45's and the dn2540's, but I was looking for something a little better. Can you really get that much current from a cascode of these? I had assumed not, but maybe I'll try it.
Old 10th April 2009, 09:05 PM   #6
Salas's Avatar
You are welcome. Yes, I=Roughly0.66/R1. Dissipation of CCS Mosfet = about Vin-Vout * I CCS. Dissipation of shunt Mosfet = (I CCS - Iload)*Vout. Arrange your sinking.
Old 10th April 2009, 09:07 PM   #7
...I've used the 10m45's and the dn2540's, but I was looking for something a little better. Can you really get that much current from a cascode of these? I had assumed not, but maybe I'll try it.
You can get ones that will give you plenty of current at low Vds, suitable for using a pair in cascode (IXYS do some), but the trouble is they don't have enough power handling. I don't know of any larger ones, but there may be some out there. You don't need to use one for the cascode though, you could use an ordinary low-threshold enhancement MOSFET with a zener or diode string to provide a bias voltage for it.
This would end up more expensive than Salas's solution, but possibly with better performance.
Old 11th April 2009, 11:27 AM   #8
I thaught the Lm317t was fine for a current source? Why would
you need better for a filiment supply? But here is an idea use the
Lm317t as a ccs but use a R C network between the ccs and the
tube something like .2ohm and 100uf and .1uf film bypass.
Old 11th April 2009, 04:30 PM   #9
AndrewT is online now AndrewT  Scotland
have you read Walt Jung's views/results/measurements of CCS performance.
I'll bet most of your questions and many others are answered in there.
regards Andrew T.
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
high current vs high voltage power Clipped Car Audio 28 19th April 2007 06:06 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 12:52 AM
high volt/high current DIY home PS. deepanger Solid State 24 13th December 2002 12:17 AM
Page generated in 0.10999 seconds (77.99% PHP - 22.01% MySQL) with 11 queries
