Hello, I have a C-audio XR3801 amplifier that have problems.
I have 2 shematics for this amplifier, the first version of the schematic is without thermistance. The second have a reference to TH D370. I found the shematic here : http://www.chaudio.co.uk/ServiceInfo/C-Audio/ The amplifier I have has no thermistance, I it has problem on a resistance : the R1 47R/23W becomes warm, and finally burns. See XR3801 soft start sheet. THe solution could be the use of these thermistances, but I can't find many informations about these. Can you help me about these D370 ??? Thanks a lot in advance for your help Robert |
#2 |
Hi there, glad my archive is useful! I only really ever set it up for my own use. It's only hosted from my house.
When the soft start resistor (R1) burns out, is the amp running normally at the time or does it have a fault? If the amp powers up normally then the problem will be to do with the relay that is supposed to bypass the resistor once the amp has started up. If the amp doesn't power up then you have another fault which needs to be fixed first. Replace the fuse in series with the resistor with a 60 or 100W lightbulb. This will limit the current and stop anything burning out immediately while you look for the main fault. |
#3 |
Hi I am looking for a service manual/schematic for the XR3801 but the link to your manuals require login details. Can you help?
#4 |
Hi I wonder if either of you could send me a copy of the schematic. I'm used to working on RA-3000's so until i hear different, i'm going to assume its one of those with way too many output fets to be stable ;-D
thanks jonathan |
#5 |
Scratch that... i've found a nice resource that really is free (at the moment).
Free Diagrams, Schematics and Service Manuals It turns out the XR output design is slightly mad... 2 sets of supply rails, like a class g or h, then 2 sets of o/p devs, in series, with a floating driver for the high set. so its possibly a class h. feel free to contradict me.. as long as it makes the thread useful to other visitors :-) |
| Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? | tiefbassuebertr | Solid State | 43 | 22nd January 2012 12:50 PM |
| For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp | tmort | Swap Meet | 5 | 27th June 2009 12:29 AM |
| Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D | jaimegmr | Car Audio | 0 | 5th May 2009 06:39 PM |
| Looking for analog audio circuit designers and audio researchers | cnotley | Everything Else | 1 | 29th September 2008 09:04 PM |
| 2.4GHz wireless audio - true lossless audio | Kay | Digital Source | 0 | 30th January 2008 10:22 AM |
| Page generated in 0.08915 seconds (75.58% PHP - 24.42% MySQL) with 10 queries |
