Impedance Matching
it depends.
Sorry, but it depends on how the receiver stage has been designed.
A non inverting stage usually likes to see a low source impedance/resistance. It also usually expects the source resistance to be nearly constant.
The gain of the non inverting receiver is independant of the source resistance/impedance. However there is an interaction between Rs and Zin which attenuates the input voltage slightly.
An inverting amplifier uses the series input resistance/impedance to set the gain of the NFB loop.
Any added resistance at the input will affect the amplifier gain.
Using a ratio of 1:10 for Rs:Rin attenuates most of the errors, but 1:20 is very slightly better.
eg.
Rin=100k allows Rs <=5k. This allows a <=20k passive pot to work effectively.
Watch for capacitance. It will interact with these higher impedances to act as a low pass filter.
A low Rs (<=200r) usually indicates universal compatibility, but do check that the source can drive low impedances.
