Old 4th April 2009, 02:38 PM   #1
Default Class A bias when using 230v for 220v transf.
I am doing some repair on an older amp, Marantz PM80 and i found that the speaker select relays are defective and i fixed that.
Next thing i checked the bias and the service manual says 18mV (50mA) in class AB and when switched in to class A 198mV(500mA).
I started to adjust the AB value from 2 to 18 no problem.
Then i went on to adjust the A value and adjusted from 90 to 200 on one channel but when i was raising the other channel and was very close to 198 the fuses blew.
I realise that class A is putting max load and the fuses is probably very close to the power output.
The fuses are 2pcs of 4A located on the AC rail to the rectifier.
I was looking at the voltages and the only thing that i can see is that the transformer is connected at 220v and i have 230v.
The transformer also got an alternate 240v winding.
Question is move to 240v winding, lower the bias or put bigger fuses in ?
The config are dual 2sa1256/2sc3182 in each channel.
Pelle
Old 4th April 2009, 03:15 PM   #2
AndrewT is online now AndrewT  Scotland
I used F4A fuses in a Ksa100 Klone biased to 2.6A
I wonder if the fuse blowing is down to an oscillation starting as the bias was increased?
regards Andrew T.
multi-channel hum, one transf, multiple PS harvardian Chip Amps 1 12th December 2006 04:32 PM
Wanted: DIY Paradise Charlize, OR Decware Taboo (220V), OR Almarro A205 (220V) Jolojl Swap Meet 0 28th August 2006 11:31 AM
Individual fixed bias and transf coupling mashaffer Tubes / Valves 3 28th February 2006 03:47 AM
Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers Eva Swap Meet 1 28th July 2005 03:00 PM
Page generated in 0.06935 seconds (70.31% PHP - 29.69% MySQL) with 10 queries
