Active Filter Four help
Old 3rd April 2009, 02:54 PM   #1
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Active Filter Four help Active Filter Four help
Default Active Filter Four help
I need help configuring the AFF for my speaker-system.
What I need:
A 12dB(24?) crossover at ~ 550Hz.
A low frequency shelf (set one to boost ~ 4,5-5 dB from 180-190 Hz and below.
A high frequency shelf set for a gradual boost from ~ 2 dB at ~4,5kHz to ~ 8+ dB at 10kHz and beyond.
Is this possible?
Arne K
Don't believe everything you think...
Old 3rd April 2009, 09:24 PM   #2
DIY !
Cobra2's Avatar
As far as I get...
Arne K
Old 3rd April 2009, 09:31 PM   #3
DIY !
Cobra2's Avatar
Speakers:
Arne K
Old 4th April 2009, 06:03 PM   #4
DIY !
Cobra2's Avatar
I tried the spreadsheet, but this only shows HP section(no LP?), and both manual & spreadsheet is missing a lot of information, unless you are a full-blood loudspeaker & filter-engineer...
Tried "TINA", this shows totally different values...
Arne K
Old 4th April 2009, 07:03 PM   #5
m2003br is offline m2003br  Brazil
Arne,
Give a visit to the site of Siegfried Linkwitz. Very good staff about equalized crossovers.
Good luck,
Marcos
Old 19th April 2009, 08:27 PM   #6
DIY !
Cobra2's Avatar
Originally posted by m2003br
Arne,
Good luck,
Marcos
THE filter-engineer writings to other engineers...
Playing around with "filterpro" finally gave me some useful numbers, implemented here.
The 20-turn trimpots were useless for finding suitable levels, removed and connected 20k stereo-pots instead.
It works!
If I now please could have some help making a low-lift, and a high-lift shelf...
Arne K
Old 19th April 2009, 10:50 PM   #7
ttan98 is offline ttan98  Australia
BTW where did get your your Active Filter 4 PCBs and you purchase your components separately?
Old 19th April 2009, 10:55 PM   #8
DIY !
Cobra2's Avatar
I have had them for some time...since the first group-buy...
The first boards were tested with "el cheapo" components, & used op-amps
Arne K
Old 19th April 2009, 11:07 PM   #9
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Arne -
The high pass and low pass are the same values, you just plug them in the appropriate spot on the board. Sorry if I forgot to put that in the manual.
I used the equal component value convention, the "Tina" calculation is probably for unity gain, which gives different values all around.
The calculator just gives you a starting point. You really need to measure the drivers in the application, calculate values, simulate, tweak, repeat.
Old 21st April 2009, 10:00 AM   #10
djk is offline djk
djk's Avatar
http://www.delta-audio.com/Active_Fi...our_manual.pdf
Candidates for the Darwin Award should not read this author.
Active Filter Four helpHide this!Advertise here!
I need an active sub filter! hernanstafe Subwoofers 18 4th December 2007 09:32 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Active Filter ChevS-10 Solid State 4 24th June 2005 05:35 PM
active filter k1jroth Chip Amps 50 1st December 2004 04:15 PM
looking for active filter sim P.Lacombe Everything Else 0 2nd January 2003 09:33 PM
Copyright ©1999-2017 diyAudio
