I'm currently having a little trouble on an EP1500 amplifier I have been working on after it experienced catastrophic failure. I have just replaced the MJE15032 & MJE15033 NPN & PNP Power Transistors along with 2SC5200 & 2SA1943 TOSHIBA Transistors which had been taking out the main module slow blow fuse on channel 1. I have also replaced the 4 Zener Diodes. Channel 2 works great but channel 1 just produces DC. Everything checks out ok but I think I may have missed out something out. I have been using the schematic and tracing all related components and all voltages check out well but this is only with a voltmeter. At the moment I don't have access to a scope. Any suggestions
Kind regards AT |
#2 |
I would be interested to see the schematics if possible and it would really help me make any suggestions.
Have you checked the feedback loop and assuming it uses one the LTP differential amplifier. |
#3 |
Make sure you didn't toast the emitter resistors of the 15032 or 15033. Or anything else besides the zeners in the bias stack-up including the 'signal present' indicator and its driver circuit.
#4 |
Such is the level of DC coupling on this type of amp that literally any component failure from back end to output can give a DC condition...its a chicken-and egg condition. I recommend extensive cold checks esp. the op-amps which can and do fail here.
| Behringer ep1500/2500 | postman | Solid State | 13 | 5th May 2009 03:19 AM |
| Behringer ep1500 and cx2310 | Beau | Swap Meet | 1 | 28th April 2009 10:59 AM |
| EP1500 blowing caps | ATech | Solid State | 22 | 8th July 2008 12:07 AM |
| Behringer EP1500 | gcohen | Solid State | 5 | 16th December 2006 08:40 AM |
| pure n channel schem. help needed | psychosteve | Solid State | 0 | 18th December 2004 12:26 PM |
| Page generated in 0.09802 seconds (74.57% PHP - 25.43% MySQL) with 10 queries |
